Hi everyone, I've just found this forum so i would like to introduce me. I'm beginner not only at macro, but in photography at all. I'm from Lithuainia (east Europe). I have canon 450 it's kit lens, 50 f1.8 and 100 f2.8. And i'm really interested in macrophotography. this is my first try:
BTW this is bubbles on the surface of tea
sole
first one
Re: first one
sole, welcome aboard!sole wrote:Hi everyone, I've just found this forum so i would like to introduce me. I'm beginner not only at macro, but in photography at all. I'm from Lithuainia (east Europe). I have canon 450 it's kit lens, 50 f1.8 and 100 f2.8. And i'm really interested in macrophotography. this is my first try:
sole
To show an image that is hosted on another site, you need to point directly to the .jpg file. The
I hope this helps. Again, welcome aboard!
(Editor / Lead administrator)
Re: first one
Welcome. Not only did you start with one of the more difficult photographic specialities but you risked getting your lens misted up!sole wrote:I'm beginner not only at macro, but in photography at all.
Harold
Also with non macro lenses make sure you don't get closer than the lens can focus or you will get fuzzy pictures. I see quite a few on a Cactus forum I am on trying to fill the viewfinder with a subject and getting closer than their lenses can focus, so their pictures are not sharp.
If you look in the information that came with your lens it should tell you the closest distance it can focus at.
Another simple test is to switch off autofocus, rack out your lens to its closest focus, put your camera on a table so you can see through the viewfinder then just gradually slide a matchbox, or some similar sized small object towards the lens until it looks sharpest on the viewfinder screen, then measure from the front of your lens to the object, then never try and get closer than that or the image will not be sharp.
If you want to go closer (larger image) you will need a supplementary close-up lens, sometimes called a close-up filter, that just screws into the filter thread of your lens:-
http://www.alanwood.net/photography/clo ... enses.html
DaveW
DaveW
