Leitz Objective
Leitz Objective
What's the meaning of the"N"in"NPL FLUOTAR PHACO 3"on Leitz objective?
[/img]
[/img]
- Cactusdave
A question that has puzzled me as well. N for "New" is a possiblity... but perhaps too obvious. This contemporary document from Leitz has some interesting info but not the origin of the "N". http://science-info.net/docs/leitz/Leit ... s_1985.pdf In any case they are excellent objectives.
- Charles Krebs
- Tardigrade37
I'm pretty sure the "N" stands for "normal". NPL objectives are semi-plan objectives and are corrected for a flat field over the "normal" field of view (ie the field observed by the camera).
Edit - Found a useful link:
http://www.microscopyu.com/articles/opt ... specs.html
About Leitz Objectives
Hi All !
NPL - NeoPlans
And this Objectives are a Semi Apocromatic Objectives
Hope this Help
Regards
Pär Lundqvist
Sweden
NPL - NeoPlans
Hope this Help
Regards
Pär Lundqvist
Sweden
****** Seeing is Believing ******
Hi everyone,
nope´, NPL stands for "normal plan", i.e., for a flat-field correction for a field number around 20. Leitz used this expression, to distinguish these (easier to build an, hence, cheaper) flat-field lenses from there top-of-the-line series, the PL lenses; those had a flat-field correction for a field number of 28. Both, PL as well as NPL lenses, were offered with achromatic and semi-apochromatic colour correction. Apochromatic lenses were solely offered in the PL-version.
Regards !
JB
Regards !
JB
Hi Pär,
I´m sorry, but you are not right. I´ve got the original Leitz booklet in front of me. In there are listed and explained all abbreviations the Leitz people have used during the "160 mm Era". And definitely, NPl means "normal plan", i.e., marks lenses, which have a flat-field correction for a field number of up to 20 ( as opposed to Pl lenses, which are corrected for the extra large field number of 28 ).
NPl also has nothing to do with colour correction, just with the extend of the correction of fiel curvature.
NeoPlan, by the way, was an expression never used by Leitz but by Reichert / Austria for their fluorit (semi-apochromatic) objectives. This label was intended to be analogous to Zeiss´Neofluars, the NeoPlans of Reichert additionally sporting a flat field of view.
Regards !
JB
Regards !
JB
I would have sworn the same thing but the papers I looked at did not have it.
At the ancient time in my memory that I was trying to recall I was working in a lab that had mainly Leitz equipment. But it was the late seventies.
Human testimony is not so reliable.
I won't Bump this as it's so old, but in Diavert instructions, page 13, NPl is Normal Plan
http://www.micromagus.net/Microdocs/diavert_manual.pdf
CR
CR
