Thanks Rik I'd seen that , now you mention it.
When you think something's right but can't remember the reason, does it become intuition??
There's another article in the back of my mind, other than that graph, (and there's another which looks very similar) relevant to coverslip thickness. It says you'd have to alter the tube length where the thickness is wrong, to compensate. So maybe we can use higher NA lenses designed for coverslips on bellows perfectly well, as long as we adjust the tube length?
This was it - I probably misunderstood it... http://science-info.net/docs/leitz/Lens ... -15-64.pdf
I have another infinity lens with this..
http://www.photomacrography.net/forum/v ... php?t=7847
That device has a 1ish inch unthreaded part I'd have to join a camera to. Any ideas?
Infinity optics:
http://www.microscopyu.com/articles/opt ... ptics.html
On using low power objectives and shorter tube lengths:
http://www.microscopy-uk.org.uk/mag/ind ... ttube.html
Nikon scope objectives.
Charles,Charles Krebs wrote:I've scanned a "Nikon CF Objectives 210 Tube Length" brochure/pricelist and put it up as a PDF file here:
http://krebsmicro.com/mplan.pdf
Thank you for the brochure of the 210 tube length, do you have the pricelist for the CF 160mm tube length (I have the brochure; but I am looking for the price list)?
- PaulFurman
Take a look at the description I just posted for a Nikon Epiphot that uses infinity tube objectives for "photomicrography in both the35mm and 4x 5 in. large film formats" but yeah, it's ridiculously expensive.Charles Krebs wrote:it may be possible to get larger image circles using some of the infinity objectives such as those made by Mitutoyo. See page 26 in this catalog:
http://krebsmicro.com/MitutoyoE4191-378.pdf
These should be used with a tube lens. The Mitutoyo tube lenses are expensive and I've only seem one for sale on Ebay in five years. The objectives are not exactly cheap either! But they have impressive working distances. Not too long before I had to pack up stuff for my move I had set up a 5/0.14 Mitutoyo M Plan Apo (wd=34mm) using a Nikkor 210mm Apo process lens as a tube lens. Works great, but makes for a big clunky arrangement on the bellows.
- Charles Krebs
Paul,
The Mitutoyo suggestion (I should have been more clear) was primarily intended for those considering "direct projection" from the objective to the sensor/film (as would be the case when used on a bellows).
The objectives on the Epiphot do not really cover a larger format by themselves, the larger formats are accommodated by various magnification photo-eyepieces in the unit. The basic image circle produced by the objective is still in the (approx) 28mm diameter range.
- PaulFurman
