New Canon 17mm & 24mm Tilt & Shift Lenses
These are due to be available in May at around £2,750 and £2,400.
http://www.dpreview.com/news/0902/09021 ... lenses.asp
Harold
Harold
I have just obtained this one (awaiting delivery), after many years of waiting:
http://zuserver2.star.ucl.ac.uk/~rwesso ... 4mmf35.htm
http://www.mir.com.my/rb/photography/ha ... mSHIFT.htm
It is shift only but some say it is the best film lens of any model made for performance. I want it for architectural use i.e. travel, buildings. I already have the 35mm version.
Harold
Harold
- Cyberspider
I don't know much about T&S lenses but 3070 EUR (3875 USD) is very much money ...It is to correct perspective, right?
best regards
Markus
SONY a6000, Sigma 150mm 2,8 Makro HSM, Extention Tubes, Raynox DCR-250
visit me on flickr
Markus
visit me on flickr
Markus,
The "shift" can correct (or distort) perspective without angling the lens - good for photographing tall buildings, for example.
The "tilt" is also very special though... like the movements on a view camera, it allows you to change the focal plane. Instead of focus being defined by how far or close to the sensor/film plane the subject is, you can define it by how high or low in altitude it is, or how far to the left and right of center.
For example, in landscape photography, you can use a moderate aperture, tilt the lens, and EVERYTHING front-to-back will be in super-sharp focus with no diffraction problems. Or for special effect, I saw an example photo where in a field of flowers, all the blossoms were in focus but the grass beneath them was out of focus.
Another funny possibility is to simulate very narrow depth of field on a large scene - this makes real life look amazingly like a tiny fake model photographed with a macro lens.
Combining tilt and shift with independent rotation makes for a very versatile lens with many applications. This kind of thing is second nature in view cameras, but generally limited to specialized lenses on 35mm format.
I see this overlaps with gabedamien's post, but I think it is different enough to be worth posting.
These lenses are critical for architectural photography on film.
In digital, the perspective correction of a tilt-shift lens can be exactly duplicated by image warping. Perspective correction is usually integrated into the same image processing framework that also corrects for barrel or pincushion distortion, vignetting, and chromatic aberration, while stitching multiple frames for increased resolution.
Tilting the plane of focus can not be duplicated by digital processing. Some of its uses can be done by stacking to increase depth of field, or by filtering to imitate reducing depth of field. But for other uses there is no substitute for tilt/shift. For example suppose you want to shoot a video of ants moving around on a tabletop, shot from the side but with the whole tabletop in focus. For that, you need a tilt/shift lens using Scheimpflug.
They have two major functions: 1) correct perspective, and 2) tilt the plane of focus (Scheimpflug principle).Cyberspider wrote:It is to correct perspective, right?
An interesting modern take I've seen to using tilt lenses is to use the tilt in the opposite way to normal to reduce apparent dof and so make the subject look smaller. I've seen several videos using this technique, of city scenes, beach scenes etc where the people appear to be tiny models moving around!
Here is a link to a thread on the subject:
http://www.photomacrography.net/forum/v ... tilt+shift
Harold
Harold
Ha,with the news we've just had we could do with a lottery win!Harold Gough wrote:As you're a mate, I'll let you have my tickets for last Saturday at half price.Cyclops wrote:I'd quite like that 17mm(equivalent to about 28mm on the Canon) but I'd have to win the lottery first.
Harold
