Earlier this month in Cyclops' Aloe posting http://www.photomacrography.net/forum/v ... highlight= I mentioned an LED ring light I had access to. As it turned out it was a fluorescent ring light. I'll present it anyway.
The light is a Samigon FRL-1.
The light works pretty well and is quite daylight ballanced. None of the close-ups seen here have any Photoshop color correction.
I would like to see more light but it is adequate for tripod or copy stand mounting. An optional mount is available for use with cameras or lenses it will not screw onto.
For more information and price see: http://www.adorama.com/IMRLF.html?searc ... &item_no=1
Most exposures for ISO 200 are about 1/30 sec. @ f 3.2 or 2 sec @ f/13.
Here are some sample photos.
Hibiscus detail
Old coin
Goethite pseudomorph after selenite
Notice circular hotspots on the specimen's shiny surface.
Detail of hard-drive controler PC board
Fluorescent close-up light
- Cyberspider
that is a very interesting thread...
What lens and what distance you had to the objects? Because if you have a 150mm macrolens i think it could be difficult to handle (?)...the working distance of my Sigma 150 is aprox. 38cm.
I'm very interested into a macroflash but i don't like the highlights some flash do in an image or in the eyes of an insect...but there are also images with a very soft light by using a flash together with a diffusor... do you have some insect pictures done with this flash?
best regards
Markus
SONY a6000, Sigma 150mm 2,8 Makro HSM, Extention Tubes, Raynox DCR-250
visit me on flickr
Markus
visit me on flickr
Thaks for the input, guys. I intended to put it in the techniques forum but misplaced it.
Cyber spider: This light is a continuous light--not a flash. It would make photographing dead insects almost a necessity. Of course, it does allow you to see the lighting results before taking the photo.
From the front end of the lens to the subjects was between 11 to 15 cm. The lamp and its removeable diffuser are about 10 cm in height altogether.
I am using a Sigma 105 mm f/2.8 lens.
Gerard: The light comes with 49, 52 and 55 mm threaded adapters. It does not directly fit my Sigma macro which has a 58 mm filter thread.
mgoodm3: Thanks for the input. This coin had enough edge darkness to show all of the markings to my taste. Since I was hand-holding the light, it would have been simple enough to tip it to the side to get more oblique lighting.
Jim
Jim
