Schneider Apo-Componon
NikonUser
Post by NikonUser »
Recently purchased an old Schneider Apo-Componon HM 40/2.8. Very compact lens and seems to be very sharp but has a fixed aperture of f/2.8 which translates into shallow focus. Thus seems most suitable for flatish subjects. 3-dimesional subjects such as fly heads need an awful lot of frames to get everything in focus.
I suspect their new lens, with diaphragm, is an excellent lens.
This is a breast feather, length 32mm, from a Mourning Dove (feather fell out of the bird while it was preening on the bird feeder).
Top image: scan of complete feather; rectangle is area photographed in 2nd image.
2nd image: portion of feather, frame size width is 4.5mm, on the 23.7mm sensor; HF stack.
57 frames @0.01mm; lens reversed on bellows.
3rd image: a 800px selection; the long "veins" are barbs and the fine filaments coming off them are barbules. The distance between the 2 arrows is 0.2mm; 7 barbules in this 0.2mm section.
NU.
student of entomology
Oliver Wendell Holmes, Sr
NikonUser
Post by NikonUser »
Face of a dung fly; same settings as bird feather. Actual width of face (eye to eye) = 1.62mm.
84 frames @0.01mm which took up almost all of a 2GB Compact Flash card.
2nd image is a 800px selection; detail is great but may need to go to 0.05mm frame spacing (=168 frames!)
NU.
augusthouse
Post by augusthouse »
Very interesting NU,
Gorgeous tone, colour and clarity in the dung fly. It's luminous! The 'shallow' depth of the stack works beautifully.
Did you mean 0.005 here? 168 images - it's worth it.
When photographing with the Nikon I tether the DSLR to the PC and utilise the time-lapse feature in Nikon Camera Control Pro 2 allowing approx. 20 secs between shots; so all I have to do is move the positioner and watch each resulting image appear on the PC screen. This method bypasses the CF card and stores the images directly on the hard drive.
The first image - the scan - of the breast feather from a Mourning Dove is superb. The detail is stunning and fascinating. The apparently textured background (intentional or otherwise) gives the image a mixed-media appearence.
Looking at these images alone, with respect of your lighting and arrangement, I would have to place the Schneider Apo-Componon HM 40/2.8 in the outstanding category.
NikonUser
Post by NikonUser »
Yes, thanks; of course 0.005mm
The scan was simply laying the feather onto the flatbed and placing a piece of regular white paper on top; thus the texture is that of the paper - pure serendipity.
I would love to get my hands on their newer lens.
A bird's feather may turn out to be a universal subject for comparing the resolution properties of a lens; possibly better and more accessible than the 'standard' moth wing.
Betty's Schneider Xenoplan 1.9/25mm is obviously an excellent lens.
SEE HERE
I'm still using a single flash. Reading all the problems asociated with fiber optics maked me reluctant to make a switch.
NU.
augusthouse
NU,
If you get a chance, could you post an image of the Schneider Apo-Componon HM 40/2.8?
NikonUser
Post by NikonUser »
Craig:
This is a very compact lens, only 29mm long. Top image photographed from "wrong side". The other side of the barrel reads "APO-COMPONON HM 2.8/4.0 MC"
It came with 2 end caps.
Lens should be used in reverse, but no thread on front end.
Bottom image.
A 48 mm ring fits nicely over the actual back of the lens.
A 48-52 ring fits nicely over the front of the lens.
The 48mm female thread accepts the 48mm male thread of the 48-52.
The 52 female thread of the 48-52 accepts the male thread of the Nikon mount.
The whole system forms a solid, no wobble, 'system' allowing the lens to be mounted reversed on the PB-6 bellows.
NU.
Post by Planapo »
Gosh! That´s one nifty way of lens mounting, that is! :D
Will try to keep this approach in mind for similar problems.
Thanks for sharing, NU!
--Betty
augusthouse
NU,
Thankyou for uploading the images and the reversal technique.
augusthouse
NU,
In the first image of the lens. The ring marked "Front" is there a thread under there or evidence of a thread?
What is the actual diameter of the lens barrel?
You've indicated that the lens should be used in reverse. Have you taken any images with the lens non-reversed?
NikonUser
Post by NikonUser »
Barrel diam. 45.0mm
Inside diam of that large outside retaining ring 25.0mm
Inner retaining ring has a thread
No images taken with lens non-reversed
NU.
Craig,
A few. This is a lens that really should be reverse mounted. (and probably used at 4x and up as well).
augusthouse
NU,
Would you mind if I uploaded some images of a similar, but alternate method of reverse mounting the Schneider Kreuznach Apo Componon HM 40mm f2.8?
NikonUser
Post by NikonUser »
Craig: Please do upload your image(s) here; an obvious place for them. Interested to see your solution. Charles has this lens also, wonder how he solved the problem.
NU.
augusthouse
A generic set of extension rings were used because they have less internal structure than the Nikon PK series and accommodate the lens with 1-2mm to spare around its diameter.
Working distance of this particular lens allows sufficient lighting to be applied to the subject without the illumination being obstructed by the setup.
Using this method to mount a lens of shorter focal length could be an issue depending on the lighting method/technique applied.
I reverse mounted a 1.7/17mm Xenoplan (with the addition of a C-mount to Leica 39mm ring). Working distance was limited.
Also used it with the SK 4/28mm; working distance was not an issue. I have some step rings on the way for reverse-mounting the latter.
The Schneider Apo-Componon HM 40/2.8 had particular requirements due to there being no useable threads on the front of the lens for reverse mounting purposes.
I'm curious about what is under that ring on the front of the lens; but I don't have the appropriate tools or sufficient experience to satisfy my curiosity.
*edit: corrected technical detail
NikonUser
Post by NikonUser »
Craig:
Your lens looks a lot newer than mine (I recall reading somewhere on this site that the 'beat-up' lenses are better performers than the 'new looking' lenses).
A very elegant mounting you have there.
I unscrewed the large ring on the front; it's simply a lens holder. Looks as though there is one large lens at the front, the one that screws off, and a separate lens at the back that remains with the barrel.
I thought the Optical Spanner Wrench used to unscrew the lens was more interesting than the lens itself, so here it is:
NU.
