Confused about RAW to JPG conversion & compression
Can someone please help me to understand why Adobe Lightbox converts a 7.23MB CR2 file from my EOS 1D Mark II to a 5.04MB JPG file, but also converts a 19.5MB CR2 file from my EOS 50D to only a 5.72MB JPG file? Same program and compression setting, but the JPG files are very close in size compared to the huge difference in he CR2 file sizes. Thanks.
Roughly speaking, a JPEG compression level of x preserves all information (detail) up to some level y, and throws away the rest.
If the image with many more pixels contains only a little more information, then it will compress to only a little bigger.
This often happens in macro work, where large areas are OOF and even the in-focus details are likely to be blurred at the pixel level.
This is also why having gobs of pixels is not nearly as important for macro/micro as it is for landscape photography.
- augusthouse
To have the RAW file and a DNG version of it, is somewhat like having a film negative or positive slide. In post production and processing you simply cannot do with a jpeg what you can do with a DNG - today or tommorrow.
RAW>DNG>TIF>.... jpeg
A jpeg can be compared to those 'instantly' developed photos that the Polaroid Instamatic provided. Handy for some purposes but certainly not comparable to a negative or transparency.
- augusthouse
