Table for macro rig
Adalbert
Re: Table for macro rig
Post by Adalbert »
Hello Leanderborg220,
system I build myself using Arduino
please take a look at that:
https://www.photomacrography.net/forum/ ... 41#p186841
COB-LED
https://www.facebook.com/photo?fbid=147 ... 0269581589
flash ( 4 * YN660 )
https://www.facebook.com/photo?fbid=120 ... 0269581589
cheap flash/continueous
1/10s is the shortest, stable exposure time I use for the flash and the fully electronic shutter.
1/15 also works, but 1/20 no longer.
The longer exposure times as 1/5s, 1s, 2s, etc. can of course also be used.
Best, ADi
leanderborg220
Post by leanderborg220 »
Adalbert wrote:
Wed Apr 28, 2021 1:28 am
COB-LED
flash ( 4 * YN660 )
Best, ADi
Hi Adalbert,
I see you are an electronics and diy guy like me :wink:
Nice system you have over there. It is very nice and satisfactoy when you build something for a fraction of the money you would need to spend when buying something that`s available. And on top of that you can make it function the exact way you need to.
COB-LED
I will be using these kind of leds, 100w and two 50watt instead of plasma flashes
https://www.aliexpress.com/item/4001181 ... 4c4dByu0m1
I can see that you are trigerring the camera just the way I`m doing it using the infrared directtly from microcontroller.
Hopefully I will have the system running soon and start taking some photos. I`m still waiting for the articulating arms from aliexpress to attach those leds, and from there I will be able to start testing.
keep you informed
leanderborg220
Still standing up :D
Until someone leans on it or bumps it from the narrow side...
leanderborg220
Finally done
Guppy
Post by Guppy »
Hi Leander
I don't understand the point of this.
Since the table is so heavy, it vibrates as much as the floor.
But the table with about 100kg is very light compared to the concrete floor (with about 1000kg?).
If the heavy floor moves then the light table moves as well.
The table will not settle down until it is on vibration dampers that are precisely adjusted to its weight.
I am interested in comparisons.
Have you measured the vibrations without the 100kg table yet?
Kurt
leanderborg220
Guppy wrote:
Sun May 09, 2021 6:15 am
Hi Leander
Kurt
Hi Kurt,
The intension of the 100kg top is not to dampen vabrations coming from the floor, but to dampen vibrations that a person might be doing on that same table, like for example using a computer keyboard or mouse.
