ray_parkhurst wrote:can it display Live View using Imaging Edge via USB while also enabling wired triggering for stacks? Can it even do wired triggering for stacks???
I have found my a7R4 (and a7R3 before that) to display Live View using Imagine Edge Remote on my Windows 10 system without problems. I'm using a Stackshot 3X rail and Zerene (Tools>Stackshot) to control the rail and capture. So,
- Win10 Imaging Edge Remote -> USB-C -> a7R4 (for the Live View)
- Win10 Zerene -> USB -> Stackshot Controller -> Multi Terminal (looks like USB) -> a7R4 (for capture)
I normally shoot in pixel shift mode. Imaging Edge automatically streams the 4 (or 16) component (ARW) images back to Imaging Edge View and creates the combined (ARQ) image. After Zerene is done and all the images for the stack have been collected, I select all the ARWs in Imaging Edge View and delete them. Then select the ARQs and save them as 16-bit TIFFs for input to Zerene stacker.
I generally use 4-image pixel-shift. I believe it produces a noticeably better result over non-pixel-shift (pixel peeping and I print large). I've tried 16-image pixel-shift but found the 4-image to produce a better result. I'd like to suss that out better at some point but haven't yet.
When I first started using this setup (using an a7R3, so it may be different now with the a7R4), I had hoped the USB-C connection would also power the a7R3, but it didn't seem to. So, I got an AC-powered dummy battery (Gonine NP-FZ100 AC Power Adapter) and except for the a7R3 (and now a7R4) warning me that the battery is not certified (or words to that effect), it seems to work OK. It only complains the first time I plug in the dummy battery so not a big deal.
BTW, I have two Windows 10 systems - an older one (dual core i7) that does the capture and a new faster one (5GHz 8-core i9) for the ARQ-to-TIFF conversion and Zerene stacking - so I can overlap my capture process on one with my stacking post-process on the other. I recently got a Synology NAS server, Ethernet attached between the two Windows 10 systems (ie. mapped to a Windows drive on each) so all the images are streamed directly to the NAS and I process them there. I use RAID 1 (mirroring) mode between two large disks for a warm feeling that my images will survive a disk failure.
My gallery:
http://svbreakaway.info/photography-mac ... p#crystals
My current setup:
http://svbreakaway.info/photography-mac ... hp#current
If this isn't clear, I'll try to post a video on Youtube later.
Mike Niemi
