www.photomacrography.net :: View topic - Spider in window well
brentbristol
PostPosted: Fri Aug 23, 2019 2:20 pm    Post subject: Spider in window well Reply with quote
I wasn't sure whether to place this topic in Nature or Studio. The spider was in a basement window well between window glass (double pane!) and the window screen. The spider was undisturbed and in a habitat that it had chosen.
Camera: Canon 7D MkII
Lens: MPE-65 1X-5X @ 2X and f5.6
10 second exposures @ ISO 100
Circular polarizer used to reduce reflections from the glass window
Cognysis Stackshot @ 75 micrometer step size, 78 images
Stacked in Zerene Stacker using Pmax. Contrast adjusted in Photoshop CS6.
Here is the setup
Here is the spider waiting for a meal:
Full size:
https://www.flickr.com/photos/brentbristolsr/48608298428/
The trouble with quick and dirty is that the dirty remains after the quick is gone.
PostPosted: Fri Aug 23, 2019 3:40 pm    Post subject: Reply with quote
This is a very nice over-the-shoulder viewpoint. It makes me feel like I'm somehow part of the spider's world, in a non-threatening way for once. Well done!
Nature forum seems to me like the right place for this, based on the aspects that you've noted: "undisturbed and in a habitat that it had chosen".
brentbristol
PostPosted: Fri Aug 23, 2019 3:48 pm    Post subject: Reply with quote
Thanks Rik. I was initially quite put off at the prospect of shooting through a double pane window. There was plenty of debris stuck on the outside of the glass and an earlier attempt at 1x had too much focal overlap between the debris on the glass and the spider. At 2X the depth of field was thin enough to separate the spider from much of the foreground debris. Amazing how a relatively wide aperture manages to "look around" foreground specks.
