www.photomacrography.net :: View topic - Great Pond Snail at the surface
dunksargent
PostPosted: Thu Aug 15, 2019 10:49 am    Post subject: Great Pond Snail at the surface Reply with quote
When visiting Langdyke Countryside Trust, Swaddywell Pit Nature Reserve near Peterborough UK on 13 August, a Great Pond Snail was spotted at the pond surface … which is normal as they 'breathe air' when required … but the specimen was also gradually 'discharging' its grit? into the water. I'm aware that they use grit to assist in grinding food but not sure if this is the same 'grit' or if its regular excreta. Any advice appreciated … thank you.
Nikon 1 J5 (monitor fitted with Zacuto optical finder) / Nikon 1 70-300mm VR plus polariser filter and extension tubes. Exposures: 300mm (810mm FF equiv) f7.1, c.1/100sec, ISO 1600.
I could not find the usual circular polariser so used a linear … which works OK with a mirrorless camera. The 300mm lens setting enables a usefully long lens to subject distance … the specimen being approx 1.5m from pond edge. Images are 'as shot' … not cropped.
Best wishes
dunk
And now for something completely different.
grgh
PostPosted: Thu Aug 15, 2019 3:56 pm    Post subject: Reply with quote
Very nice find.
Good shots, right place and right time.
used to do astronomy.
and photography.
Zeiss Universal Phase contrast.
Zeiss PMII
brentbristol
PostPosted: Tue Aug 27, 2019 6:45 pm    Post subject: Reply with quote
Equal parts serendipity and wonder! Thank you for sharing.
The trouble with quick and dirty is that the dirty remains after the quick is gone.
