Stentor
Moderators: Chris S., Pau, rjlittlefield, ChrisR
Post Reply
blepharopsis
Stentor
Post by blepharopsis »
Finally, I found a protocol that works pretty well for preserving swimming form of Stentor for immunohistochemistry - maybe with some tweaking I'll get a fully extended one. From Huang & Pitelka (J. of Cell Biol. 1973, Vol. 57): "Cells in the extended state were obtained (...) by treatment before fixation with a solution containing 10 mM EGTA, 50-80 mM Tris, 3 mM MgSO4, 7.5 mM NH4Cl, 10 mM phosphate buffer (pH 7.1)".
Staining - anti-acetylated tubulin mAbs (cilia - red);
DAPI (DNA - blue);
I also used actin marker Alexa 488-phalloidin, but's it's known to fail to recognize protozoan F-actin - the green channel is mostly a combination of bleed-through signals for both blue and red channels and some autofluorescence.
The first image (a compilation of 7 individual scans) shows stentors fixed with formaldehyde only - cells collapse a bit due to osmotic stress, some rupture, but the signal from surface cilia is strong. The second image - I used just a dash of glutaraldehyde - the preservation of the cell shape is better, but I feel that glutaraldehyde messes up with the exposed epitopes in surface cilia, judging from weaker signal. The bases of cilia still stain fine.
Zeiss LSM 880, 40x NA 1.3.
:shock: :shock: :shock: :shock: :shock: WONDER !
Olympusman
Stentor
Post by Olympusman »
Amazing!
zzffnn
Post by zzffnn »
Wow! Great professional work and amazing images. This is Nikon Small World material. Igor, have you sent them for an image competition?
blepharopsis
Thanks!!
Zzffnn - as a matter of fact, yes - but not exactly those two.
75RR
Post by 75RR »
striking images!
Zeiss Standard WL & Wild M8
Olympus E-p2 (Micro Four Thirds Camera)
WalterD
Post by WalterD »
Stunning images, Igor. Innovating, creative and visually overwhelming.
Hope too see much more :)
Harald
Post by Harald »
Hi blepharopsis,
This is great.
Exceptional images. Love the last one.
Thanks for sharing :D
Kind Regards
Harald
Lier Fotoklubb / NSFF
AFIAP / CPS
BGF / GMV
Igor,
Wow, amazing images!
The second one was with 40x too?
Smokedaddy
Post by Smokedaddy »
What else can I say but excellent.
Never seen this level of clarity and detail of this fragile species before.
Robert Berdan
Truly amazing photos
Post by Robert Berdan »
Very impressive images of Stentors - I will give the technique a try.
Thanks for sharing.
RB
Marek Mis
Post by Marek Mis »
Igor, your confocal images are from different plannet ! Fabulous !
Thank you for sharing.
Regards,
Marek
Marvelous!!!!!!!!!!!!!!!!!!!!!
Post Reply
