A ~ 10X photo of the back of a dolichopod's head. This fly inhabits the muddy bank of a stream. The male hovers over the female about 2cm back looking over her folded wings and toward the back of her head.
I puzzled over these spots till I observed the courtship and now suspect that the spots are what he uses to maintain his position. Eventually he lands in front of her, then flies back to the rear and hovers some more. If she is pleased, she waves her wings a bit and they become more intimate.
stereo of rear head by Keith Short, on Flickr
Stereo of the back of doli's head
- MarkSturtevant
MarkSturtevant wrote:
uv pmax by Keith Short, on Flickr
Similar view with white light
front portrait by Keith Short, on Flickr
As you can see, the fine white fuzz on the fly’s face really lights up.
In white light the face looks white in a face-on orientation, and dark from below. I am not sure if this is to allow the fly to flash white to dark by nodding, or if it helps the fly avoid alerting its prey in the mud below where it normally feeds.
I will try to check out the patches with UV. Thanks for the comment!
Keith
As coincidence would have it I photographed the face of this species with soft UV LED lights several years ago.These iridescent markings might be strongly UV reflective.
Keith
And here is an image of the back of the head in UV. The blue patches don’t lite up more than other areas. I don’t know if this is because the orientation allowed UV to reflect away, but I suspect not. I think the patches are blue as the eyes of the bug may be tuned to blue wavelengths for max sensitivity not UV. The puddles where these bugs feed result in the light passing through a water surface and back out. UV polarized light in water de polarizes rather quickly relative to longer wavelengths. And UV is somewhat more quickly attenuated in water than blue light. So there may be physics behind the color of the blue patches as blue light sensitivity may be advantageous for the bug.
Other species that are not mud puddle feeders may well be most sensitive to UV and key on UV flags as the water surface attenuation won’t be important.
K
uv stereo head rear by Keith Short, on Flickr
K
Very interesting and wonderful stereos!
Visit my Flickr albums
- MarkSturtevant
