www.photomacrography.net :: View topic - Beach Sand
Beach Sand
Goto page Previous  1, 2
Smokedaddy
PostPosted: Sat Jun 08, 2019 12:48 am    Post subject: Reply with quote
Figured I would add a stereo pair of the original posting. A larger image can be seen here;
https://squattingdog.smugmug.com/Stereo-images/i-rXDG2w2/A
-JW:
PostPosted: Sat Jun 08, 2019 7:45 am    Post subject: Reply with quote
Looks good, except this one is laid out for parallel viewing, not crossed-eye.
Smokedaddy
PostPosted: Sat Jun 08, 2019 10:46 am    Post subject: Reply with quote
... thanks, this is out of my range of understanding. It looked fine with my stereo Pocket 3Dvu glasses 'or' cross-eyed. Here's one with the left and right swapped.
-JW
rolsen
PostPosted: Sat Jun 08, 2019 11:29 am    Post subject: Reply with quote
You have to change the order to get them cross-eye, now they are in wrong order.
- Rane
enricosavazzi
PostPosted: Sat Jun 08, 2019 12:56 pm    Post subject: Reply with quote
Smokedaddy wrote:
I don't have a lot of experience photographing things like this, including lighting but here it is.
[picture]
The two pink/violet ones are fragments of the capitulum of balanid barnacles. The third of course a gastropod.
Smokedaddy
PostPosted: Sat Jun 08, 2019 1:20 pm    Post subject: Reply with quote
Thanks, at least I have something to go on now. I've never even heard of the term, gastropod, or what a Paleobiologist might do. Rolling Eyes Looks like it might be closely related to this;
http://txmarspecies.tamug.edu/invertdetails.cfm?scinameID=Busycotypus%20spiratus#
Regards,
-JW:
PostPosted: Sat Jun 08, 2019 3:39 pm    Post subject: Reply with quote
If it looks good both ways, that says your personal visual system is not very sensitive to depth inversion by itself. I get the feeling that's pretty common -- it seems like a lot of people have trouble distinguishing correct from inverted with scenes like this where nothing in the foreground hides anything in the background. Depth inversion is much more obvious with scenes where say one leg passes in front of another, or an antenna passes in front of a face. In that case if the depth gets inverted, then it looks like the thing in back hides the thing in front (!), and most people will recognize that at least to the level of "looks weird".
Smokedaddy
PostPosted: Sat Jun 08, 2019 4:08 pm    Post subject: Reply with quote
Like this hair (or whatever it is) and the changing depth of the yellow arrow ...
-JW:
PostPosted: Sat Jun 08, 2019 6:22 pm    Post subject: Reply with quote
Smokedaddy wrote:
Like this hair (or whatever it is) ...
In concept, yes. But this is not a very good example because the hair is thin and not very far in front of featureless background. The effect is most obvious when the foreground occluder is larger and is much farther in front of richly textured background, so that the stereo depth of each object is clearly established.
Smokedaddy
PostPosted: Sun Jun 09, 2019 5:20 pm    Post subject: Reply with quote
... I thought it was interesting how much finer the sand was from Kailua Beach Hawaii compared to Cabo San Lucas (not that this image was a good candidate for a stereo pair.
-JW:
Page 2 of 2
