As a teaser, What's that? (solved so title changed)
The colour is misleading, I left it because it shows information.
Galling on Alumin(i)um alloy
Yes, it's alumin(i)um alloy "galling". It's happened in an epi illuminator, where the cubes are slid across.
It had become tight, and came to me with one of the slider-arms missing, presumably broken at its weak point, where the second one had bent.
That's despite the grease costing $968 per kg.
A microscope repairer advised that a light lithium grease would do, but I may look for something anti-seize.
The grooves do look deep, don't they? But the entire stack (M20x) is only 60µm or so. It was tilted a little to give some shadow, and the depth of the grooves was just covered.
The trenches are in focus, and FOV is APS length/20 so about 1000µm.
They do look a lot more than 1/20th the field width deep, huh?
The funny colour is Auto balance, on flash .
This is the male dovetail surface. The carriers are a brass/bronze alloy.
