100:1
Cornel
100:1
Post by Cornel »
Some fly eyes and butterfly wings at 100:1 magnification
JL
Post by JL »
Very impressive !!!! :shock:
Adalbert
Post by Adalbert »
Hi Cornel,
Very nice!
What about your equipment you have used for ... ?
BR, ADi
Very nice indeed. In order to interpret these, it would be helpful to know the sensor size. Objects at 100x on FF would appear half the size of those same objects on MFT.
Olympusman
Fly eyes
Post by Olympusman »
Remarkable!
Adalbert
Post by Adalbert »
Hi Lou,
Yes, you are right. I have just checked my old picture taken by APSC (1,6) and lens 50x:
BR, ADi
rolsen
Post by rolsen »
Awesome to see so clear pictures at this mag.rate.
- Rane
gremlin
Post by gremlin »
super detail, way beyond me
Sumguy01
Post by Sumguy01 »
=D> Very nice.
Thanks for sharing.
Cornel
Post by Cornel »
I used Nikon d610 + Raynox DCR 150 + Nikon LU Plan BD 100x NA 0,80 + 2 flases + Mjkzz rail.
The corners are ok-ish with this setup, only cropped to remove the banding from alignment (at this magnification the frame moves all over the place with my setup).
The rail goes down to 0,3um step size but it doesn't have the precision for it, so I used 0,9um, seemed ok in my tests.
The hardest thing is to bring enough good light on the subject, working distance is 3,5mm and the objective is BD type so it's very thick (don't know if I can remove the outer cover, tried and it it didn't worked). The eyes are so much harder to lit and stack the frames in a pleasing way.
Anyway I'm pretty happy with the results, It's been a goal of mine ever since I began doing extreme macro a few years ago (you know what I'm talking about, It's like a drug, you have to go higher and higher...:) ), and it's nice to see the progression from 1:1 to 4:1, 10:1, 20:1, 50:1 and now 100:1. Didn't skipped any steps which allowed me to learn a lot along the way and to a reasonable 100:1.
Thanks to everybody who contributed to this forum, it definitely helped a lot.
lonepal
Post by lonepal »
Congratulations, very nice.
I also dream to make a stack @100X
Regards.
Omer
Adalbert
Post by Adalbert »
Hello Cornel,
I know this problem, so I had to saw my Oly MSplan:
BR, ADi
The very high mag BD's have a sprung mount, which makes it not so easy to remove the outer barrel - I haven't managed it.
I would be tempted to use the BD feature instead of fighting it. The vertical illuminators can often be found cheap on eBay. I am currently working to set one of them up for a BD objective in a DIY rig....
Howard Mayo
Post by Howard Mayo »
Great images!
Thanks for sharing.
