If I start Zerene via LR-plugin and save the project, then the following error occurs:
Code: Select all
5,397: accepting file C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051\IMG_0565.tif
5,450: Preferred size of left panel = java.awt.Dimension[width=264,height=315]
5,451: Preferred size of right panel = java.awt.Dimension[width=800,height=800]
5,453: after resetToPreferredSizes(), leftWidth = 264, rightWidth = 2033
5,550: OpenedImageFile: imageFileName = C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051\IMG_0462.tif
5,551: OpenedImageFile:dispose C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051\IMG_0462.tif
5,553: Trying to read C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051\IMG_0462.tif
6,185: mfileImage = BufferedImage@679e7e97: type = 0 ColorModel: #pixelBits = 48 numComponents = 3 color space = java.awt.color.ICC_ColorSpace@6e671038 transparency = 1 has alpha = false isAlphaPre = false ShortInterleavedRaster: width = 6000 height = 4000 #numDataElements 3
6,186: Read image file with ImageIO.
6,410: EXIF Orientation = <none specified>
6,413: bi propNames = null
6,415: Image file length = 144020118, modification time = Tue Dec 11 09:51:04 CET 2018
6,415: Preferences.PREROTATION_SELECTED=false
6,416: Preferences.PREROTATION_DEGREES=0
6,417: Preferences.FILEIO_IGNOREEXIFORIENTATION=false
6,418: EXIF Orientation from file = <none specified>
6,418: Image size as read from file, width=6000, height=4000
6,423: in FloatArrayYUVImage, final preRot = 0
6,930: YUV image construction = 0.507 seconds
6,931: FloatArrayYUVImage constructed from image, width=6000, height=4000
6,955: RapidApproximateColorSpaceConverter, constructing new from java.awt.color.ICC_ColorSpace@6e671038
7,030: RapidApproximateColorSpaceConverter: successfully read profile from cache file.
7,780: Time to load image C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051\IMG_0462.tif = 2.227
8,438: Time to load image C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051\IMG_0462.tif = 0.657
8,438: Original Image Size = java.awt.Dimension[width=6000,height=4000]
8,459: Current maxMemory() = 4194304000
8,521: getUnregisteredPreviewImage(IMG_0462.tif successful read from original source.
8,524: Synchronously writing preview file C:\Users\Adalbert\AppData\Local\Temp\ZereneStacker\unnamedZSproj20181211095654257\previewimages\-Unaligned-0.jpg
9,838: Done writing preview file C:\Users\Adalbert\AppData\Local\Temp\ZereneStacker\unnamedZSproj20181211095654257\previewimages\-Unaligned-0.jpg
9,839: OpenedImageFile:dispose C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051\IMG_0462.tif
9,864: DisplayPanel::paintComponent -- using slosh-prevention method A
9,952: getUnregisteredPreviewImage(IMG_0462.tif finds cached image in memory.
191,092: for LR project, saveChooser.getCurrentDirectory() = E:\MULTIMEDIA\FOTO\CANON_EOS_M3\2018_12_11\M20_mitty
195,936: FileDialog 'visible' for 4843 milliseconds
195,958: Saving project to directory E:\MULTIMEDIA\FOTO\CANON_EOS_M3\2018_12_11\M20_mitty\zsp
195,959: done = false and isNamed() = false
196,041: java.lang.NullPointerExceptionIgnoring KeyEvent java.awt.event.KeyEvent[KEY_RELEASED,keyCode=10,keyText=Eingabe,keyChar=Eingabe,keyLocation=KEY_LOCATION_STANDARD,rawCode=13,primaryLevelUnicode=13,scancode=28,extendedKeyCode=0xa] on null.glassPane
196,085: Ignoring KeyEvent java.awt.event.KeyEvent[KEY_PRESSED,keyCode=10,keyText=Eingabe,keyChar=Eingabe,keyLocation=KEY_LOCATION_STANDARD,rawCode=0,primaryLevelUnicode=0,scancode=0,extendedKeyCode=0x0] on null.glassPane
196,088: Ignoring KeyEvent java.awt.event.KeyEvent[KEY_TYPED,keyCode=0,keyText=Unbekannt keyCode: 0x0,keyChar=Eingabe,keyLocation=KEY_LOCATION_UNKNOWN,rawCode=0,primaryLevelUnicode=0,scancode=0,extendedKeyCode=0x0] on null.glassPane
196,089: Ignoring KeyEvent java.awt.event.KeyEvent[KEY_RELEASED,keyCode=10,keyText=Eingabe,keyChar=Eingabe,keyLocation=KEY_LOCATION_STANDARD,rawCode=0,primaryLevelUnicode=0,scancode=0,extendedKeyCode=0x0] on null.glassPane
196,189: at com.zerenesystems.stacker.engine.j.G(Project.java:2539)
196,207: at com.zerenesystems.stacker.engine.j.H(Project.java:2594)
196,207: at com.zerenesystems.stacker.engine.j.c(Project.java:208)
196,208: at com.zerenesystems.stacker.gui.MainFrame$an.run(MainFrame.java:3755)
196,210: at java.base/java.lang.Thread.run(Unknown Source)
196,578: Autolog timer delay doubled
197,069: Autolog timer delay doubled
198,071: Autolog timer delay doubled
200,072: Autolog timer delay doubled
204,073: Autolog timer delay doubled
In this case I have to copy the generated TIFF-files manually.
from: C:\Users\Adalbert\AppData\Local\Temp\Lightroom_Export_to_ZereneStacker_20181211095051
to: E:\MULTIMEDIA\FOTO\CANON_EOS_M3\2018_12_11\M20_mitty\zsp\...
Does anybody know this problem?
BR, ADi
