i have four LENS
first I use the xenon 28/2 + 5.9/120(0060) NOT GOOD
ALSO XENON 35/2 +5.9/120(0059)
BY SONY A7R2 3x flash ad200
shot about printer
and also I test bu laowa 25mm use about 3.5x
sorry about schneider Makro 5.9/120 + XENON 35/2
I pool English,sorry to some time
I haven't tried that particular combo, but it seems to perform very well in Robert's tests.
It is hard to judge by the single shots you posted, but the result does not look that bad to me.
The best way to determine how good or bad it does, would be comparing it with some "reference" lens, such as the Mitu 5, if you have one. Maybe you have your expectations set too high.
- Macrero
- Macrero
Re: sorry about schneider Makro 5.9/120 + XENON 35/2
So I tried a similar test method. The picture is taken in 10PICS sheets of 20 UM using RAW in HF. 100% near the center.
I just have mittitutoyo 10x 50x soso Crying or Very sad
I am very grateful to the two selfless help, I have learned a lot of knowledge here, and also shot a lot of works.
TWO,You are my idol:!:
TWO senior,You are my idolMacrero wrote:I haven't tried that particular combo, but it seems to perform very well in Robert's tests.
- Macrero
Well, the Mitty 10 plays in another league. The first images are too small as to assess and compare properly. In the laser printed paper test, the Linos image looks indeed better. But that are single shots, right? Can you make a stack with each lens and post the result? Ideally with a link/s to high-resolution images.
- Macrero
