Wanted to do use the x/y table on the microscope so I tried my normal tube lens Apo Gerogon 150 mm with an Apo Ronar 360mm as tube lens.
Stitched
I also tried with some 3D objects - stacked.
Low CA, good corners on FF but could probably do better with a lens with a larger aperture, this is f9.
Best regards
Jörgen Hellberg
Apo Gerogon 150 mm with Apo Ronar 360mm as tube lens
Nice results Jörgen!
The first question that comes to mind is, how did you manage to mount that massive lens, I saw an image years ago of someone using that 360mm lens for macro and the entire rig was over 3 feet in length, sorry over a meter long and the lens was wider than the photographers hand
