I have the floating optics 150mm Printing-Nikkor (1/4-4X) en route to me now. I wanted to query the community on experience with this lens and see if anyone can confirm my suspicions on the quality and image circle.
Based on coinimaging tests up to around 1.4X the corner sharpness improves quickly as magnification increases. Also, resolution seems to remain outstanding up to the tested ~1.4X.
Based on the information available online it would seem this lens was designed for converting various film formats and based on conventional wisdom the image circle should grow as the magnification increases.
I made the image below based on the standard film sizes.
If we take the sharpest aperture to be f3.3 (based on coinimaging results) the effective aperture at different magnifications would be (based on 1+Mag x fstop = effective aperture)
Using 5um pixels as a baseline for when diffraction sets in, I get these results:
@f3.3
1X / 30mm IC: f6.6 (below diffraction limits for ~5um pixels)
2X / 60mm IC: f9.9 (below diffraction limits for ~5um pixels)
2.3X / 70mm IC : f10.89 (right at diffraction limit)
3X / 90mm IC : f13.2 (diffraction sets in)
If f2.8 maintains quality at higher magnifications then the results would be:
@f2.8
2X / 60mm IC : f8.4 (below diffraction limits for ~5um pixels)
3X / 90mm IC : f11.2 (right at diffraction limit)
4X / 120mm IC : f14 (diffraction sets in)
Wondering if anyone has real world experience with this lens that might manage my expectations on what tests to pursue when the lens arrives. I currently have a Phase One IQ150 (44x33 sensor @ 5.3um pixels) but am thinking of getting the 100MP or 150MP Phase One sensor when I can afford it - if the quality holds at higher magnification and larger image circles it would make this lens stand out even more than it already does.
