www.photomacrography.net :: View topic - Quartz crystals in small geode
peterkinchington
PostPosted: Sat Jul 07, 2018 6:29 pm    Post subject: Quartz crystals in small geode Reply with quote
My wife is a keen rock hound - she found this small geode with quartz crystals inside on a roadside gravel pile outside Camberville in the Yarra Ranges in Victoria. I photographed a 10mm section with a stack of 100 images using ambient light and a reversed 36mm cine lens on about 43mm of extension.
My wife liked the detail around the imperfection in the central crystal so I photographed it with the same technique but with a reversed 13mm cine lens.
Try, try again. Fall down nine times get up ten.
www.peterkinchington.com
dolmadis
PostPosted: Sun Jul 08, 2018 12:57 am    Post subject: Re: Quartz crystals in small geode Reply with quote
Nice result.
Would you mind posting which lens you used please, Peter?
BR
John
peterkinchington
PostPosted: Sun Jul 08, 2018 4:09 am    Post subject: Reply with quote
Hi John,
It was a Yvar 36mm f/2.8 cine lens.
Cheers Kanga
