www.photomacrography.net :: View topic - Tiger Beetle (2)
Tiger Beetle (2)
Goto page Previous  1, 2
PostPosted: Wed Jun 20, 2018 6:20 am    Post subject: Reply with quote
Yup, I'd say relay lenses are different - eg where you use a short FL wideangle and look at its aerial image with a relay lens.
Quote:
if a "Nikon lens from an enlarger"was any use to me
Of the 50/2.8 lenses, the newer plastic "N" one is a little better than the older metal one.
The f/4 isn't great. Use it as a loupe! 75mm is less poor, but easily beatable. Quite variable between individual lenses. Way back I compared about 8 50/2.8s.
mjkzz
PostPosted: Wed Jun 20, 2018 6:29 am    Post subject: Reply with quote
Lou Jost wrote:
Mike, the EL should be stopped down one or two stops to be really sharp, but it's hard to say whether the best place to do that is in the lens or behind it. When the tube lens is much longer than the front lens, then the front lens' aperture is often usable. When the two lenses are similar in focal length, the paper aperture is almost always best. This is an intermediate case, so an empirical test would be worthwhile.
Rik has pointed out elsewhere that the default should be to stop down a combination somewhere between the two lenses.
Theoretically the combination can be made telecentric with the right choice of aperture position.
Thanks Lou, I am still trying to cut an aperture for it as you mentioned in previous post, to be positioned in between.
Lou, Mike : I stopped it down to f/4, at f/2.8, I saw some CA on another subject, stopping down reduces it to almost nothing. Also, I used a segment of M42 tube (via a M42-to-M39 step down ring) as hood, else, for my light setup, the images are washed out.
https://www.facebook.com/groups/mjkzzfs/
mjkzz
PostPosted: Wed Jun 20, 2018 6:30 am    Post subject: Reply with quote
There is a Rayfact one, looks identical to mine (plastic version), do you know anything about it? It is about twice as expensive.
PostPosted: Wed Jun 20, 2018 12:28 pm    Post subject: Reply with quote
No, sounds interesting though. Link? A lot of their products are for very specific uses.
mjkzz
PostPosted: Wed Jun 20, 2018 8:32 pm    Post subject: Reply with quote
It is on Taobao
PostPosted: Thu Jun 21, 2018 4:12 am    Post subject: Reply with quote
Ah - see http://www.tochigi-nikon.co.jp/en/products/lens/il.htm
"... Interchangeable with EL-NIKKOR lenses (40mmF4N, 50mmF2.8N, 63mmF2.8N, 75mmF4N) whose production has been terminated by Nikon Corporation...."
mjkzz
PostPosted: Thu Jun 21, 2018 6:14 am    Post subject: Reply with quote
thanks Chris
Page 2 of 2
