www.photomacrography.net :: View topic - Recommended virus-free auto mouse clicker?
PostPosted: Mon May 14, 2018 11:35 am    Post subject: Recommended virus-free auto mouse clicker? Reply with quote
I am using a sensor-cooled astrophotography camera that can't be directly triggered by WeMacro or Cognysis controllers, so it is hard to synchronize the exposures with the rail movements (each is controlled by an independent laptop).
Astrophotography software allows me to set the time interval between captures, but only to the nearest second, and the software (at least the one I use, Sharpcap) doesn't start counting the time until the end of the exposure and file writing. If exposure + write time is not a whole number of seconds, the sequence becomes dis-coordinated with the rail movements (which only use whole numbers of seconds, not fractional seconds).
The solution is to automate mouse clicks on the "capture" button of the astro software, setting the correct interval between clicks based on the settings of the rail controller.
Can anyone recommend a simple mouse record/play autoclicker with adjustable time interval between successive clicks? I have done some reading and Free Mouse Auto Clicker is often recommended. These kinds of free programs, though, are often full of viruses and bloatware, particularly if they are downloaded from general-purpose software-downloading sites. Can anyone recommend a safe auto-clicker program, from a safe download site? Is Free Mouse Auto Clicker safe?
Thanks in advance,
Lou
www.loujost.com
manu de hanoi
PostPosted: Mon May 14, 2018 1:08 pm    Post subject: Reply with quote
https://www.google.com/search?q=macro+software
PostPosted: Mon May 14, 2018 1:27 pm    Post subject: Reply with quote
Thanks, I had read about that one, but it has a mediocre rating. Do you have personal experience with it?
www.loujost.com
pierre
PostPosted: Thu May 17, 2018 10:44 pm    Post subject: Recommended virus-free auto mouse clicker? Reply with quote
ZS with Robot function Wink
Regards
Pierre
PostPosted: Sat May 19, 2018 7:47 am    Post subject: Reply with quote
Pierre, that just works with Stackshot as far as I could tell. I suppose I could run a dummy Stackshot while using the WeMacro rail...but I'd rather find a simpler solution.
www.loujost.com
elf
PostPosted: Mon May 28, 2018 6:32 pm    Post subject: Reply with quote
Do you have the Pro version of Sharpcap? If so, have you looked at their SDK?
PostPosted: Mon May 28, 2018 9:27 pm    Post subject: Reply with quote
Lou,
Assuming you're running Windows, how about Microsoft Mouse and Keyboard Center? (Download link here.) I haven't used it, but it should certainly be safe.
PostPosted: Tue May 29, 2018 5:11 am    Post subject: Reply with quote
Elf, I don't have the pro version, but I would certainly get it if it had this ability.
www.loujost.com
PostPosted: Tue May 29, 2018 5:13 am    Post subject: Reply with quote
ChrisS, thanks for the idea, I will investigate. In all the lists of macro automation programs on the web that I had looked at, this had never turned up. But it does seem like such a basic task that Windows should have the ability to do it, hidden somewhere in some obscure place.....
www.loujost.com
PostPosted: Tue May 29, 2018 5:37 am    Post subject: Reply with quote
Chris, I just installed it. It appears to only work with an external keyboard or mouse, not the laptop's keyboard or trackpad (and then maybe only Microsoft keyboards or mice?)....what a dumb self-limitation. This suggests, though, that Windows might have a separate built-in equivalent for the native keyboard or trackpad...maybe.
www.loujost.com
anoldsole
PostPosted: Wed May 30, 2018 2:17 pm    Post subject: Reply with quote
I suggest http://www.macrocreator.com/ It's a good tool for macro and script generation, powerful without being too difficult to use. Highly recommended if you need to automate simple tasks on a computer.
PostPosted: Wed May 30, 2018 2:36 pm    Post subject: Reply with quote
Have you looked at http://www.robot-soft.com/ ?
elf
PostPosted: Wed May 30, 2018 2:42 pm    Post subject: Reply with quote
The Sharpcap pro version says it has scripting. Have you tried contacting them?
PostPosted: Wed May 30, 2018 5:26 pm    Post subject: Reply with quote
Thanks for the suggestions Rik, elf, and anoldsole. The Macro Creator looks best for me, in that it will be able to control other more complex programs as well.
www.loujost.com
