www.photomacrography.net :: View topic - Question about vibration
stevocem
PostPosted: Sun Apr 08, 2018 3:32 pm    Post subject: Question about vibration Reply with quote
Hi guys
I use Nikon D800 with Mitutoyo 20x Plan Apo lens. As tube I use Nikon 200mm macro lens.
I noticed that my live view is good, sharp but every time I shoot an image, it is blurred. I tired quiet mode and also shutter delay mode, with 3 seconds mirror lock up. No noticeable difference, live view is sharp, images not. I tired to go up with ISO and to reduce the exposure time to extremely fast, still no luck. What is going on? Any ideas are welcome. Thanks in advance.
Stefan
PostPosted: Sun Apr 08, 2018 3:57 pm    Post subject: Reply with quote
Stefan,
Might be shutter shock caused from the shutter curtains moving. I use the D800 with the Mitty 20X and have been able to get good results.
This is where flash can help. For example in studio work sometimes, I'll set a long shutter exposure, say 1 second, but use rear curtain flash for the actual exposure. This needs to be done in an environment where the long shutter exposure won't expose the image with ambient lights, only the flash creates the exposure.
~Mike
stevocem
PostPosted: Sun Apr 08, 2018 11:26 pm    Post subject: Reply with quote
Thank you Mike! Sadly, my setup doesn’t allow flash. I am trying to snap micro images on varnished paintings, which reflect a lot. I need to setup special lights... Flash doesn’t work with this setup. Any other ideas? Many thanks.
Stefan
PostPosted: Sun Apr 08, 2018 11:55 pm    Post subject: Reply with quote
Have you tried relatively dim light and long exposures, say 8 seconds?
The idea is to get the bulk of exposure in quiet time after the shutter vibration has died out.
PostPosted: Mon Apr 09, 2018 5:30 am    Post subject: Reply with quote
Stefan,
You might be able to use flash (strobes) with a highly diffused light modifier. I often image chips which have highly reflective surfaces and use a small light tent to diffuse the multiple strobe. Under extreme conditions like when these chips have many tiny solder balls (40~100um dia), which tend to be highly reflective like spherical mirrors, I may use two light tents a smaller one inside a larger one. This works very well for creating a highly diffused light source.
With this technique you can use the flash (strobes) but still get a highly diffused light source, and employ rear curtain flash synch mentioned.
These tents are not expensive, usually under $50.
~Mike
Deanimator
PostPosted: Mon Apr 09, 2018 10:43 am    Post subject: Reply with quote
And easily duplicated using PVC pipe and fabric. This gives you easy customization, even on the fly, as well.
anoldsole
PostPosted: Mon Apr 09, 2018 4:40 pm    Post subject: Flash option Reply with quote
If you are worried about spectacular highlights with flash, one option might be to use cross polarization. Get some polarizing film and cover your softboxes with linear polarizing sheets (align the polarization), then put another piece of film in front of the objective with the polarization oriented orthogonally with your lights polarization. You'll lose a few stops of light but it will tone down the highlights of the flash so you can still utilize it's high speed vibration stopping power.
