www.photomacrography.net :: View topic - finite objectives for APS-C
jurkovicovic
PostPosted: Mon Mar 26, 2018 11:52 am    Post subject: finite objectives for APS-C Reply with quote
Hi folks,
I should have a request.
I would like to ask for administrators and more experienced members.
Could you publish a list of finite objectives suitable for APS-C with good working distance?
Thanks. BR.
PostPosted: Mon Mar 26, 2018 10:29 pm    Post subject: Reply with quote
Jurkovicovic,
Here are some that I use. This is a classic group of lenses for finite use.
Nikon N Plan CF Apochromat 4/.20 WD 15mm
Nikon M Plan CF 10x/0.25 WD 9mm
Nikon N Plan CF 10/0.30 WD 9.2mm
Nikon M Plan CF 20/0.40 ELWD WD 10.5mm
Nikon M Plan CF 40/0.50 ELWD WD 10.1mm
Nikon M Plan CF 60/0.70 ELWD WD 4.9mm
If you'd like to see pictures of them, check out the fifth image down in this post.
PostPosted: Tue Mar 27, 2018 12:31 am    Post subject: Reply with quote
Agreed.
At the low-magnification end there's a number of other objectives which are good, eg Lomo 3.7x NA 0.1 , which are much cheaper.
Most 10x finites have several mm working distance, which is OK.
Edmunds Finite 10x is good .
A relevant post:
http://www.photomacrography.net/forum/viewtopic.php?p=228128#228128
When you're at say, 20x, there aren't many choices.
