www.photomacrography.net :: View topic - Adapter M52x075 -> M42x1
lothman
PostPosted: Thu Jan 04, 2018 12:34 pm    Post subject: Adapter M52x075 -> M42x1 Reply with quote
Is there an adapter available adapting a 52mm filter to M42 thread?
lonepal
PostPosted: Thu Jan 04, 2018 12:44 pm    Post subject: Reply with quote
https://www.ebay.com/itm/Reversing-Ring-M42-52mm-Pentax-Screw-Fit-52mm/262360684379?epid=1463868721&hash=item3d15ea575b:g:RQkAAOSwGYVW-8Ch
Regards.
Omer
lothman
PostPosted: Thu Jan 04, 2018 1:36 pm    Post subject: Reply with quote
thanks but that is a reverse adapter, I would need an additional female female 52 tube in order to screw in a 52 filter
RobertOToole
PostPosted: Thu Jan 04, 2018 3:36 pm    Post subject: Re: Adapter M52x075 -> M42x1 Reply with quote
Hi Lothman,
Not sure if this would help but Raf camera made these for me for the same purpose, but to mount a tube lens! I use the same type of adapter now and they are very useful to have.
(There is a typo in the listing, the thread is M52 x 0.75.)
PostPosted: Thu Jan 04, 2018 4:02 pm    Post subject: Reply with quote
They do exist, as step up rings:
http://www.ebay.co.uk/itm/1-one-Step-Up-Filter-Ring-Adapter-Black-METAL-42mm-to-52mm-42-52-mm-M42-F52-mm/220540884843?hash=item335942d76b:g:iX8AAOSwiVhZvVyc
PostPosted: Thu Jan 04, 2018 4:27 pm    Post subject: Re: Adapter M52x075 -> M42x1 Reply with quote
Relevant?
https://www.ebay.com/itm/M42-x1-to-M52-Step-up-Step-down-Ring-Female-Male-Coupler-Adapter-Pack-of-2/222624705596
Also https://www.amazon.com/Gadget-Place-42mm-1-0mm-Adapter/dp/B01F6XZ7F8, though the last time I ordered one of those, the machining was not so good -- right pitch but depth visibly off.
lothman
PostPosted: Thu Jan 04, 2018 4:47 pm    Post subject: Re: Adapter M52x075 -> M42x1 Reply with quote
rjlittlefield wrote:
Relevant?
Thanks Rik, that is exactly what I was searching for. I used "M42x1" without a blank, may be that's the reason why I found nothing.
Chris I'm not sure if this 42x1 or the usual filter thread M42x0.75
RobertOToole wrote:
Hi Lothman,
Thanks Robert, I do not need the length but otherwise this would have been a solution.
