Any suggestions for either building one or using a stackshot at about 20x and below?
-Thank you
building a automated focus rail
When you're starting out, it's much easier to just buy a stackshot, mjkzz, or WeMacro rail with controller and software. Building your own system, with ready-made rail, is possible. Building your own rail is quite a bit more involved.
The biggest obstacle is the stepper and how to control it. Most likely you will end up using a stackshot, mjkzz, or WeMacro controller to run the stepper, so starting with one of their rails seems natural.
Going one step further, better rails are available fairly readily. THK and Misumi make excellent rails that can be integrated with stackshot, mjkzz, or WeMacro steppers and controllers, and can give you higher resolution stepping. This is fairly involved and many rail types exist. It's easy to buy the wrong model, and will take some work to integrate into a working system, but ultimately will give a superior product.
It all depends on your skill level as a designer, machinist, and software developer
The first step is to write out a full list of requirements. Here's a few hardware and software items to start with:
- Budget.
Minimum repeatable step size (with tolerances).
Backlash tolerance.
Maximum weight.
Studio or field setup with or without handholding capabilities.
Horizontal or vertical or both.
Vibration dampening.
Power requirements. Battery or mains.
Lighting/multiple flash attachment points.
Flash or natural light.
Diffusion attachment points.
Subject stage with XYZ movements.
Bellows capabilities. AFAIK, no commercial rails have this.
Panorama capabilities. AFAIK, no commercial rails have this.
Video capabilities.
Interface with Zerene Stacker, Helicon Focus, or other tethering options.
Image capture rate.
Touchscreen, Smart phone, Android or iPhone, and/or computer control.
Did I mention Budget.
