www.photomacrography.net :: View topic - My Macro System
My Macro System
Goto page Previous  1, 2, 3, 4  Next
lonepal
PostPosted: Sat Jul 01, 2017 1:26 am    Post subject: Reply with quote
Interesting..
I live at 2nd floor of an apartment.
There are 2 roads passing 5 meters away from the apartment.
I have no vibration issues so far.
I usually make stacks at nights to fully avoid vibrations.
I also think the frequency and intensity of the vibration is very important.
Regards.
Omer
PostPosted: Sat Jul 01, 2017 3:23 am    Post subject: Reply with quote
Congratulations Omer Smile. You got all your bits, obviously!
PostPosted: Sat Jul 01, 2017 5:55 am    Post subject: Reply with quote
One thing I've found that really helps with external vibration is to NOT use a solid connection between the optical base and the floor.
I use a pair of Rubber Maid storage tubs under my optical bench which hosts the rail system and subject. These plastic tubs act as a low pass filter for high frequency vibrations.
Being an EE I tend to think of this as adding a higher structural impedance between the source (floor) and the load (optical rail). Adding weight to the bench (load) reduces the load impedance and also increases the vibration attenuation as does the tubs.
Around 1978 I consulted on the development of a system to cut complex contact lenses, kind of a CNC machine for contact lens. University Optics was the company and eventually acquired by B&L. We had large pillars of concrete in the ground isolated from the building foundation supporting a large massive granite optical table hosting the system. We still had vibration problems, so we added an air bag between the granite table and the pillar. This solved the external induced vibration problem. We ended up building 6 systems to handle the production. The air bag acted to increase the impedance between the pillar and granite table and thus increase the vibration attenuation.
Whatever reasoning you chose, this just works for me and is simple and cheap!!
Hope this helps,
lonepal
PostPosted: Sat Jul 01, 2017 6:05 am    Post subject: Reply with quote
Thanks Chris!
I am open for advices to improve it.
Regards.
Omer
lonepal
PostPosted: Sat Jul 01, 2017 6:12 am    Post subject: Reply with quote
Hope this helps,
Dear Mike;
Thanks for the tip.
I actually tought to put all the system on a air bag like thing.
But I could not find any proper airbag for this.
For example;
My solid wooden table is 500X500.
If I can find an airbag like 400X400X50 it will fit superfine.
I can place the airbag between the wooden table and marble plate.
But I think it is hard to find such an air bag, what do you think?
Regards.
Omer
PostPosted: Sat Jul 01, 2017 6:36 am    Post subject: Reply with quote
Something like two of these? :
https://www.mec.ca/en/product/5046-861/Air-Pillow
PostPosted: Sat Jul 01, 2017 7:36 am    Post subject: Reply with quote
Mike, yes, I think the principle is almost the same as the bags filled with viscous fluids. The fluids, however, have an additional damping effect through molecular "friction".
www.loujost.com
austrokiwi1
PostPosted: Sat Jul 01, 2017 8:22 am    Post subject: Reply with quote
I use square versions of these:
http://www.ebay.com/itm/4-SORBOTHANE-SORBO-2in-50mm-VIBRATION-ISOLATION-FEET-PODS-70D-NEW-TURNTABLE-/370987953166?hash=item56609aec0e:g:bFEAAOSwPYZU6rBM
Still learning,
PostPosted: Sat Jul 01, 2017 8:37 am    Post subject: Reply with quote
Hope this helps,
Dear Mike;
Thanks for the tip.
For example;
I would look into a bean bag chair as an alternative to the air bag. I was going this route if the Rubber Maid tubs didn't work.
PostPosted: Sat Jul 01, 2017 8:46 am    Post subject: Reply with quote
Agree with the friction. The bean bag idea should do something similar at a larger scale I would think. The tubs worked for me (they absorb vibration energy by expansion and contraction and thus dissipate some as frictional heat. They also act as a base to mount the optical bench on, if I wanted the bench to be higher I could stack tubs (they are designed for such).
Having the bench about 20" off the floor allows more access and eases the lighting from above. I am using a small light tent sitting over the subject and positioning fixture with the lens front poking thru a slit in the tent side. With this setup I can position my multiple strobes around and over the tent for better illumination uniformity. This seems to work well for my situation.
Anyway, hope this helps others with vibration issues. As you well know they can be a pain to reduce or eliminate, we all have been thru that!!!
BTW vibration is the main reason I use strobes rather than continuous lighting, and heat also.
PostPosted: Sat Jul 01, 2017 9:21 am    Post subject: Reply with quote
Austrokiwi, thanks for the Sorbothane links. I'll try them. Also will try the tupperware containers...
www.loujost.com
PostPosted: Sat Jul 01, 2017 10:41 am    Post subject: Reply with quote
I believe I have also heard of people setting their table legs on dry sand in buckets. Seems like that might work pretty well, except for maybe having to periodically reset the legs if they gradually work down into the sand.
But I have no personal experience with any of the more extreme approaches. My work area is pretty quiet and Sorbothane pads are sufficient.
PostPosted: Sat Jul 01, 2017 10:48 am    Post subject: Reply with quote
I imagine it would be very hard to maintain a level platform if it were set in sand. Not a problem for solid subjects but a problem for things in shallow dishes of alcohol.
www.loujost.com
lonepal
PostPosted: Sun Jul 02, 2017 2:37 am    Post subject: Reply with quote
Dear Chris good find.
But I am not sure about that can hold the marble plate and all the equipments on it?
No information about max load or something.
Regards.
Omer
lonepal
PostPosted: Sun Jul 02, 2017 2:40 am    Post subject: Reply with quote
Hi.
I already made some investigations about sorbothane long time ago.
But it is too hard for me to buy original sorbothane.
The sellers on ebay are not trustable and I heard lots of things about fake sorbothane Smile
Good sellers do not ship to Turkey as well.
So I use rubber, it does the job well.
Regards.
Omer
Page 2 of 4
