www.photomacrography.net :: View topic - Increasing Manual Rail Precision?
Deanimator
PostPosted: Mon Jun 12, 2017 7:36 am    Post subject: Increasing Manual Rail Precision? Reply with quote
Lately, I've been using a reversed Minolta manual 50mm lens reversed onto manual extension tubes.
This obviously precludes the use of DSLR Controller for focus stacking, necessitating the use of my cheap Chinese manual rail.
The problem is achieving uniform movement.
While I could zero out the rail and put a mark on the knob at 12:00, I think it would be easier to use if there were some kind of simple dial face against which to reference the mark/arrow on the knob.
Does anyone have or know about a solution for this? I have Corel Draw, so I can print a circle and gradations. I was thinking I could print it on card stock and laminate it. I could possible glue that onto thin wood, plastic or metal.
Any ideas?
Beatsy
PostPosted: Mon Jun 12, 2017 8:44 am    Post subject: Reply with quote
Does your rail have a standard micrometer adjustment? If so, the bottom half of the cases that writeable DVDs come in have a perfect push-fit hole in the bottom (the inside of the post that holds the DVDs). It just pushes onto the end of the micrometer handle. Maybe you have one laying around?
You hold and spin the post for quick movement, or use a fingertip on the edge for fine adjustments. I just put evenly spaced tick marks around the edge and lined those up with something on the table to gauge evenly spaced steps by eye.
Deanimator
PostPosted: Mon Jun 12, 2017 10:08 am    Post subject: Reply with quote
Yes, the rail is one of the typical X-Y focus rails.
What I was thinking of was printing out a vernier scale (I found a good one) and laminating it. I'd then glue that to a disk (metal, plastic, or woord) that I would (somehow) affix to the rail, behind the knob. I could then paint/glue an indicator mark on the knob.
Deanimator
PostPosted: Mon Jun 12, 2017 10:36 am    Post subject: Reply with quote
You don't know how the knobs on those generic rails come off, do you? Do they just pull off? I'm trying to avoid breaking anything I can't afford to replace.
Beatsy
PostPosted: Mon Jun 12, 2017 10:59 am    Post subject: Reply with quote
The DVD case just slides over the standard handle without taking it off. I can't really suggest how to remove a handle without seeing it (if that's what you need to do). Sorry.
Deanimator
PostPosted: Mon Jun 12, 2017 11:39 am    Post subject: Reply with quote
The ones that I have don't slip over the knob.
I just did a stack of 23 trying to use the linear scale. It's still processing through CombinZP.
