aspolat's macro shots
Hello everybody, this is my first post in the forum. actually i have been reading here long time, but i have never been ready to write I am also not good in english.
I started macro photography three months ago. on that times i had not enough equipment. I had only D7000, 105mm macro and raynox msn-202.
I decided to make a slider for macro because i did not have one. but i had "LEGO mindstorm ev3" set. i could have used that. and i did
the following photos and video shown my story of starting to macro.
https://www.youtube.com/watch?v=Vnzi0GGPjl8
Nikon D7000 + nikkor 105mm f/2.8 VR + Raynox MSN-202
stock flash with handmade tube for light transporting
enjoy...
enjoy...
OnlineMarkSturtevant
Eventually, i finished to make final macro set-up. This process has taken long time. Thanks to mirrorless dslr (with efsc) and some vibration-reducing parts vibro problem is almost gone.
I used four pieces for reducing vibration under the set-up. this pieces made of Bridge-Girder elastomeric bearing plate (which use on bridge construction).
For Vibration Reduction by Samil POLAT, on Flickr
The solid table and supporting equipment by Samil POLAT, on Flickr
My Final Macro Set-up by Samil POLAT, on Flickr
And one of the first shot, I could not find a new specimen due to winter. I had to use a very old and dirty house-fly for that reason.
Sony A7II + Nikon PB-6 bellows + Raynox DCR-150 as a tube lens + Mitutoyo M Plan Apo 5X microscope objective
2 x IKEA JANSJÖ led light
2" ISO50
157 shots combined with ZERENE and Bugslabber
"Dirty Hoar Housefly" by Samil POLAT, on Flickr
2" ISO50
Samil POLAT
Flickr
Flickr
Rove Beetle
Sony A7II + Nikon PB-6 Bellows + Raynox DCR-150 as a tube lens + Nikon CF Plan 10X 0.30 EPI microscope objective
Magnification: 12X
2 sec. ISO50
203 shots combined with ZERENE and Bugslabber
Kind of Termites (I guess) by Samil POLAT, on Flickr
Magnification: 12X
2 sec. ISO50
Samil POLAT
Flickr
Flickr
I will guess that the 2nd insect is a kind of rove beetle. Although there is some diversity in their form and size, a similar one looks like this:
http://bugguide.net/node/view/167778/bgpage
Mark Sturtevant
Dept. of Still Waters
@Searust
Cause i prefer continuous lighting rather than flash. Led lighting is not as strong as flash lighting. So, if you want to get enough exposure on your photo than you should keep open your shutter how much you need.
@MarkSturtevant
more like this, also it has not bottom clamp like beetle
http://bugguide.net/node/view/434679[/quote]
@MarkSturtevant
Samil POLAT
Flickr
Flickr
Nice pictures!
I had never heard of the use of "Bridge-Girder elastomeric bearing plates" before. In your opinion how good are they at minimizing vibrations?
Regards Jörgen
Regards Jörgen
Thank you @JH
I have also never seen anywhere like mine. But i think all work with same basis. they consist of elastic material and reduce vibration.
to get back your question
I am kinda newbie about macro, and i was using nikon d7000 up to a month ago. When i upgraded my setup to mirrorless (sony), that was big revolution for me. Big part of my vibration problem is gone.
I think i need some more experices to say something about my vibration reducing pieces performace.
And I will...
in conclusion; "theoretically they should work fine" said my engineer insight
"Rove Beetle with mitu"
Magnification: 5X
2" ISO50
125 shots combined with ZERENE and Bugslabber
Termites at 5X by Samil POLAT, on Flickr
And I will...
Magnification: 5X
2" ISO50
Samil POLAT
Flickr
Flickr
Hate to continue on about this, and it is a small matter but i really think this is a rove beetle. There are 1000's of species, diverse in size and color and proportion. Look at the dorsal side, and I bet you will see the front wings are modified into short elytra.
Mark Sturtevant
