The console log does contains alignment information, as shift, rotate, scale numbers.I am truly surprised that I do not see any shifts, neither translational nor rotational.
Not sure if Zerene Stacker has matrix logged in log view to verify this
Your image, reproduced here from the previous page:
With respect, I disagree. This image looks awful. If this were actual pixels, not the whole frame resized, then I would say that it appears to be motion blurred. But being the whole frame, I'll say that it appears to be severely motion blurred.Though the image is not as pretty, but it illustrates how good the setup is.
If you have alignment turned off in the software, then this could be due to slight frame-to-frame shifts being combined by PMax.
But if you still have alignment turned on (as suggested by asking about the matrix, plus the apparent dust trails in the image), then I think the problem must be vibration causing blur in the individual frames.
If the problem is not vibration, then perhaps this objective has been damaged by dropping. If the objective is really this bad, it should be returned as obviously defective.
I calculate even smaller, f/56 (=50/(2*0.45). But you're giving diffraction too much power here. f/56 will certainly be very blurred at actual pixels, but with the full frame scaled to web size, the image should again look sharp. Many excellent images have been posted using that same model of objective.just realized something, it is an 50X objective with NA of 0.45, meaning effective aperture is f/49!!! Diffraction is killing the sharpness
