www.photomacrography.net :: View topic - *FOUND* StackShot
*FOUND* StackShot
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Equipment Exchange
BLCaya
PostPosted: Sat Oct 08, 2016 8:44 pm    Post subject: *FOUND* StackShot Reply with quote
Looking to use with a new Canon MP-E 65mm. Please PM me with condition and price. Thanks!
BLCaya
PostPosted: Tue Sep 03, 2019 6:09 pm    Post subject: Stackshot Reply with quote
Bumping this with the hope someone still has one for sale. Sad
PostPosted: Tue Sep 03, 2019 7:02 pm    Post subject: Reply with quote
Do you really need the extended model?
If your stack is more than a couple of inches deep then moving the camera or subject on a rail is probably not the best solution anyway, for the reasons explained at https://zerenesystems.com/cms/stacker/docs/troubleshooting/ringversusrail .
In most cases, a better solution then the extended StackShot is to pair a regular length StackShot with some long coarse positioning system, like a 300mm Arca rail and a double-sided clamp to fasten the StackShot to that. The combo gives you more total range than the extended StackShot, at less cost, and with greater rigidity.
BLCaya
PostPosted: Tue Sep 03, 2019 8:24 pm    Post subject: Reply with quote
Hi Rik -
Good point. No, I do not need the extended. Originally I wanted as much "flexibility" as possible but given the information you provided I will update the title if possible. A "regular" stackshot would work exactly as I hope.
Thank you so much for your thoughts and for sharing the link/information!
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Equipment Exchange All times are GMT - 7 Hours
