www.photomacrography.net :: View topic - Antenna of an ant
Antenna of an ant
JH
PostPosted: Tue Jan 19, 2016 3:36 pm    Post subject: Antenna of an ant Reply with quote
Hi
This is the antenna of an ant (formica sp).The first photo is from my test with a Baader fringe killer filter. The only noticeable effect of the filter is in this case a shift in the WB - wich I have corrected.
Regards Jörgen
Mitutoyo 20x, LED, Baader fringe killer filter
Mitutoyo 20x, Semi X-pol EPI, cropped
PostPosted: Tue Jan 19, 2016 5:34 pm    Post subject: Reply with quote
Excellent
Sumguy01
PostPosted: Tue Jan 19, 2016 8:36 pm    Post subject: Reply with quote
Nice.
Thanks for sharing
PostPosted: Tue Jan 19, 2016 9:12 pm    Post subject: Reply with quote
As I understand it these filters are just cutting out the highest and lowest wavelengths to minimize chromatic aberrations in non-apo lenses. Since your lens is an apo, it makes sense that you would not see any effect except a color shift. But it would be interesting to try it on a cheaper non-apo lens!
www.loujost.com
PostPosted: Wed Jan 20, 2016 5:09 am    Post subject: Reply with quote
Very nice
JH
PostPosted: Thu Jan 21, 2016 10:11 am    Post subject: Reply with quote
Thanks for the comments!
I had some hope that the filter would take care of the little CA that is pressent when I use my Mitutoyo 20x.
I can see that the subject and the light affects the amount of CA but I do not know if there is variations in CA with different samples of the lens or if the distance between the lens and the tube lens matters.
Regards Jörgen
JH
PostPosted: Sat Jan 23, 2016 4:04 pm    Post subject: Reply with quote
Here is a comparison at 100%, Nikon M plan 40x 0.5. PMax.
To my eyes there is a very small difference in this case. In other tests that I have done I could not find any difference at all.
Here is the final picture Nikon M plan 40x 0.5. PMax, Baader fringe killer filter.
Regards Jörgen
PostPosted: Sat Jan 23, 2016 5:38 pm    Post subject: Reply with quote
Thanks...looks like there is a very slight purplish cast to the dark background details in the non-filter sample, which is not present in the filtered sample. Interesting to know about this option anyway.
www.loujost.com
JH
PostPosted: Sun Jan 24, 2016 1:41 am    Post subject: Reply with quote
Thanks Lou Jost
When I checked this thread for updates using an Android tablet I realize that I need a better screen to be able to see the purple.
Regards Jörgen
zzffnn
PostPosted: Sun Jan 24, 2016 8:27 am    Post subject: Reply with quote
Beautiful photos. Thank you!
PostPosted: Sun Jan 24, 2016 8:40 am    Post subject: Reply with quote
"I realize that I need a better screen to be able to see the purple."
Screens matter very much. Sometimes a wide-gamut screen with a lot of saturation can be very useful for judging color problems. Other times a very low-contrast screen with a low gamma value can reveal otherwise-invisible problems in dark areas of a photo; a contrasty screen makes them invisible. It is useful to look at stuff on both kinds of screens. And it is best to calibrate and profile one of your monitors.
www.loujost.com
