A question about Tiyoda 1x 0.025 objective.
I would like to know if this spring loaded objective can stay fixed at the up position with some sort of push and twist motion or am I supposed to use my fingers to keep it in the up position?
there happens to be one similar to mine on ebay...
http://www.ebay.com/itm/SPRING-LOADED-P ... 3d044fa949
Thanks for the reply, but I guess I should've been more specific or maybe asked in a different forum? I'm using it on a dslr and Im trying to get the image bigger(the image is in a circle and black fills the rest) and while doing so I've noticed a large improvement when the lens is up. Again, thanks for the reply, because I do intend to use it on my microscope...,but on a dslr do you think there's a way to keep the lens up?
There's probably no built-in mechanism for locking the lens up.
No doubt you can add one, using any of several DIY methods involving adhesives and so on.
However...
That lens is designed to be used at 1:1, at effective f/20 (=1/(2*0.025)), and with vanishingly small working distance -- hence the spring.
Used within the frame of a microscope, it provides a valuable service for imaging a field the same diameter as the eyepiece stop.
Used outside the frame of a microscope, it will perform the same service, but suddenly that's a lot less valuable because any ordinary macro lens or repurposed enlarger lens will give the same magnification, with much longer working distance, over the full field of the sensor, and with a wider optimum aperture which implies a sharper image and faster exposures.
So I'm wondering, are you sure you want to jury-rig this lens to do that job?
However...
