Hi there,
puzzledpaul wrote:Hi George - Interesting looking rig you've got there
Since you indicate the possibility of further changes, I wondered if mounting the camera + bellows on a single board / piece of material was under consideration?
Cheers
pp
Not at the moment. Most of the images I will take with this setup are likely to done without the bellows. If you take the bellows off, it looks a much more balanced system. In fact, the setup was made without the bellows in mind. I didn't know you could get an adaptor so that I could attach my Nikon lenses to it.
You'd then end up with a 3 point mount (as now) but one that made angular mis-alignment of the bellows axis less likely...
If you're saying this because you see what appears to some misalignment in the current setup, then what you see is actually barrel distortion dut to the fact that I use a wide angle lens to take the latest image. When I look at the setup by eye, it looks dead straight. I calculated the dimensions of the supports to keep things as level as possible.
If I was starting over with the bellows in mind, I would probably have mad it as a single platform. However, due to the variable dimensions of the different combinations of accessories, there would still needed to have been temporary support blocks built into the system somewhere.
Thanks for the thoughts.
