Hello Microcopists,
I reads already one while with you also. After some days as registered participants comes now my first picture. This concerns a thin cut (20µ) by the needle of a Schwarzkiefer. The cut was colored following with Etzold.
I hope it find favours.
Many greetings Erik
A thin section by the needle of the Schwarzkiefer
Erik, welcome to the forums!
If I understand correctly, this is a cross section of the needle of a European Black Pine tree.
It is beautifully prepared and photographed -- great detail. How did you cut the section? What power and NA objectives did you use?
Thanks for posting -- we look forward to seeing many more!
Hello Rik, thank you for the nice words.
"... How did you cut the section? ..."
I used an old microtome for students of E. Jung from Heidelberg (100 years old).
The needle of the Black Pine Tree is inserted first into AFE and been to to cut into elder Marks. AFE consists of alcohol, glacial acetic acid and Formalin (10: 1: 1).
"... What power and NA objectives did you use? ..."
I use an older microscope of Carl Zeiss Jena (earlier GDR, type Jenalab-Pol). For the first picture I used a 6,3x plan achromatic objective, for second a 50x plan apochromatic objective. Both photos free-handle taken up by the eyepiece with a Olympus C-40.
Erik
Erik
- Charles Krebs
Thank you for the cordial welcome.
"... and we hope to see many more ..."
I will try it “class instead of mass” to deliver here.
Many greetings
Erik
my homepage:
http://www.mikroansichten.de
Many greetings
Erik
my homepage:
