www.photomacrography.net :: View topic - My new Mitutoyo 10X is very good!
Goto page Previous  1, 2
typestar
PostPosted: Sat Oct 19, 2013 3:24 am    Post subject: Mitutoyo M Plan Apo 10x --- "newer" design Reply with quote
Very interesting, Rik,
I believe, most of the Mitutoyo 10x users in this fine forum use the
"older" version, with the lens NOT recessed but showing outside (black front ring around the lens) -- the older official Mitutoyo Model Parts No. for this is 378-803-2
(as Craig Gerard shows his lens) -- I can find the "older" lens listed already 2004 for $ 668.00
Now, the lens is listed at Mitutoyo with parts number 378-803-3
to be found on this Mitutoyo PDF:
http://www.mitutoyo.com/wp-content/uploads/2012/11/E4191-378_010611.pdf
I got (in march 2010 already) my lens a optically new and the 378-803-3 number is already printed on the original plastic-container,
but tehe barrel looks the same as Craig Gerard shows it -- (with black front ring)
Is this also the parts number of your 10x model? (sticked on the original plastic container)
As written above, Edmunds site still pictures the "older" version, black front ring), unfortunately...
Thankyou for your information,
best wishes:
typestar
PostPosted: Sat Oct 19, 2013 4:15 pm    Post subject: Re: Mitutoyo M Plan Apo 10x --- "newer" design Reply with quote
Yes:
Code/Parts No. 378-803-3
Model M Plan Apo 10X
typestar
PostPosted: Sun Oct 20, 2013 8:17 am    Post subject: Mitutoyo 10x parts number 378-803-3 Reply with quote
Rik,
thankyou for the fast answer. So the parts-number has not been changed /increased - but obviously the barrel-construction did.
regards,
christian
PostPosted: Wed Oct 30, 2013 12:11 am    Post subject: Reply with quote
Since I recently purchased an Edmund Optics Hi-Resolution USAF target, Stock #58-198, I decided to see how that target is rendered by the good and bad Mitutoyos, as well as a Nikon CFI60 comparison lens. These are all shot with Mitutoyo MT-1 tube lens plus a 1.4X teleconverter so I don't have to struggle so much with possible sensor effects.
As before, the results here are clear and obvious --- once they're all in hand. But if that left image weren't available, then given the other two, I'm again suspicious that I would reach the same conclusion that I did initially: nice for CA, not as sharp as the Nikon CFI60, but not obviously defective either. Hhmm... Sad
Edit: to fix broken link for target.
pierre
PostPosted: Wed Oct 30, 2013 11:56 pm    Post subject: Reply with quote
Interesting results.
Thanks for the share Rik.
Regards
Pierre
FrancisCC
PostPosted: Wed Jan 15, 2014 12:44 am    Post subject: Mitutoyo clones Reply with quote
There is a good chance there are clones of the Mitutoyo objectives like these. As there are Nikon=like clones available too on Ebay.
Being resourceful is the key
View user's profile Send private message AIM Address
PostPosted: Wed Jan 15, 2014 1:00 am    Post subject: Reply with quote
FrancisCC, welcome aboard!
Do you have specific information about forgeries, that is, objectives that say "Mitutoyo" or "Nikon" but actually are not?
Or are you talking about objectives that more or less imitate the appearance and specs, but do not misrepresent the brand name?
Yousef Alhabshi
PostPosted: Wed Jan 15, 2014 4:02 am    Post subject: Reply with quote
I recall seeing a few Mitutoyo's clones on E-bay. They looks excatly the same as the original but un-labeled (maybe they are some differences I'm not aware of). The seller claims they that they are excatly the same as Mitus.. which means they were not the real ones.
I was wondering at that time, how difficult it is for one of these sellers to get those clones laser typed in order to looks like the originals?
PS I just did a quick search & couldn't find them anymore.
http://www.flickr.com/photos/alhabshi/
Page 2 of 2
