This is a spider egg case attached to a small blade of grass. The large end was about 1-2 mm across. Note the tether wrapped around the base of the stem.
There is an inner globe of fine silk surrounded be a heavier protective layer.
Leica MZ16 stereomicroscope w/extended depth of field imaging system
An Amazing Structure
Steve Valley - Albany, Oregon
- Charles Krebs
- Bruce Williams
Nature is so amazing up close....super find Steve, and a great set of photos. Anyone home? On a side note, there is a post on the macro forum discussing the hairs on a lacewings` wing. Do you know why there would be hairs on a wing?
Doug, the hairs on insect wings probably have multiple functions. The escape from spider web scenario sounds plausible. They also probably have a sensory function during flight. They would also increase lift by trapping a layer of air on the upper surface of the wing that acts as part of the wing. They also create turbulance that can aid lift. I am mostly gussing here, so don't read to much into it. Almost all my knowledge about insect flight comes from my studies of dragonflies, and their flight is distinctly different from other insects. They flap their fore and hind wings independently and can use the hind wings to take advantage of the turbulence caused by the forewings. That is part of the reason they are so manuverable. And yes, they also have some hairs on their wings that are thought to be sensory.
- Bruce Williams
