www.photomacrography.net :: View topic - Zerene editing issue
stevekale
PostPosted: Thu Feb 09, 2012 8:37 am    Post subject: Zerene editing issue Reply with quote
I had a play with the demo of ZS today. Certainly a wonderful piece of software. I wanted to raise one thing that puzzled me though. It concerns painting content from a source file.
Here is a small piece of the Dmap image I used as a starting point:
I was painting from this source:
and am puzzled why it should produce such dark output:
(PS why can't this forum software handle file names with spaces in them?)
PostPosted: Thu Feb 09, 2012 12:10 pm    Post subject: Re: Zerene editing issue Reply with quote
It's because the stuff you're painting is so close to a large bright area.
You're probably expecting the retouching brush to paint pixel values. That's a completely reasonable expectation, but it's not the way the brush works. What the brush actually does is to paint differences of values. In this case, the feather and background that you're painting are represented in terms of differences from their surroundings in the source image. Those surroundings are bright, so the information painted by the brush says "darker than surroundings". But when "darker than surroundings" gets painted onto the target image where the surroundings are already dark, the result is "darker than you'd like".
Painting differences normally works well, especially for retouching from PMax output to DMap output which was the primary design goal. But in some cases, like the one you have here, it's far from ideal. See the long thread HERE for discussion of the tradeoffs.
Very briefly, the gradient of darkness reflects proximity to that big bright blur, relative to the size of the area that you retouched at one go.
The problem would become less severe if you used a much smaller brush and traced each bit of the feather independently, but that's painfully tedious.
You might prefer instead to export the aligned images (File > Save Other > Save Adjusted Input Images), then pull them into Photoshop where you can use other types of brushes.
Staying within Zerene Stacker, the best approach is usually to retouch from a PMax output rather than original source, because PMax is most likely to have done some acceptable job of sorting out this difficult situation.
Switching subjects, I'm a little curious about what optics you're using. When I played with the images that you posted, I noticed that there's a big scale difference between the two images. Here's what I got when I lined up the two by matching details on that feather:
The scale ratio between these is like 3:2. Are you focusing by bellows back draw, or did you post the images at different scale?
From a technical standpoint, it's because the pattern-matching code doesn't recognize the [img] [/img] pair if there are any spaces between them. I have no idea whether that's a bug or an explicit design decision by the folks who wrote phpBB. The workaround is to replace the space by its escaped equivalent, %20, as I've done in the image above -- file name "2-image overlay.gif" represented as "2-image%20overlay.gif" within the img tags. Many browsers will do the substitution automatically if you copy/paste the URL from the address bar.
stevekale
PostPosted: Thu Feb 09, 2012 1:28 pm    Post subject: Reply with quote
Thanks for the editing explanation Rik. Yes I was expecting it to paint pixels values. I'll take a read through the other thread and circle back if need be.
The Pmax output doesn't seem to like specular highlights (and would appear to compound them?). Here's a clip of the Pmax output
I think the sizing issue is just my rough cropping - it was quick 'n dirty to show this particular area. I had not cropped 'actual pixels'. Next time I will use the Marquee tool. The optics are simply a Canon 100mm f2.8L Macro on a full set of Kenko tube extensions.
PostPosted: Thu Feb 09, 2012 2:13 pm    Post subject: Reply with quote
That's correct, especially if "compound" means "put together in interesting ways". There are several common ill effects:
1. Contrast increase, causing brights to blow out in the composite where they did not in the individual frames.
2. Blooming, often accompanied by starlike patterns such as discussed HERE.
3. "Inversion halos" where background goes dark around bright foreground and vice versa.
Your example here shows these, but it also shows some effects that don't fit the usual patterns. The apparent broadening of the wire of the hook, with apparent sharp detail on both sides, makes no sense to me in terms of processing a single well behaved stack. I have seen similar results on occasion when I've accidentally included frames from another stack shot with slightly different perspective, and I'm wondering whether that might have happened here in your PMax output.
stevekale
PostPosted: Thu Feb 09, 2012 2:31 pm    Post subject: Reply with quote
By "compound" I believe I meant your item 1. Thanks I will read this other thread as well.
All the images input images were from the same stack run and in order.
stevekale
PostPosted: Fri Feb 10, 2012 3:20 am    Post subject: Reply with quote
Perhaps one of the most compelling arguments for a "paint pixels" feature? Wink
