This site published these specs and comments:
- A high performance telephoto macro lens developed especially for close-up photography. Large magnification ratios (up to life size) can be obtained without an Auto Extension Tube while maintaining distance from the subject.
- Lens Composition 7 elements, 7 groups Correction of aberration at close range with floating elements; Angular Field 24 degrees; Minimum Focus 0.41m (16 in) (1:1); Diaphragm action MM fully automatic; F-stop scale f2.8-4-5.6-8-11-16-22; Filter Size 67mm screw-in type; Lens hood 67mm G-13 soft hood, screw-in type No. 5 metal hood (with 67/86 ring), screw-in type; Weight 740 grams (1.63 lbs); Lens size 76x86.5mm(3x3-3/8 in); Lens pouch No 2; Lens cap 67mm K-61, snap type.
Shipping is free, but you have to pay for any pay-pal fees. (There's always a 3% transfer fee from pay-pal to my account but the other fees can be zero by using a "gift" option as I understand it.
PS: I have two of these lenses and they have different original contax front caps - one is a friction-fit and the other is a typical spring-loaded type. So if you're buying this lens please specify a preference.
Thanks!
Also I would be willing to trade this for a Canon 1D Mark IIn with a low shutter count, in excellent condition, and with 2 or 3 batteries + charger.
Here's the images:
The lens on the left is the one I'm selling but both are shown side by side here so that you can see the two different types of Contax original lens caps.
The one on the left is the typical plastic spring-loaded style cap. The one on the right is rubberized friction-fit type - maybe with a metal core - it's rubber all over but it doesn't bend like rubber.
