Homemade equipment
Homemade equipment
as the title suggests, have you ever built or used something on a microscope or camera that you made with your own hands.
I made my own darkfeild, not hard.
you need a filter carrier under your condenser, and a spare ground glass filter to go in, then take opaque black card, and cut a circle 15 mm across, and place this in the middle of your filter and look down the microscope. totally black, the circle is too big, white edges, too small. do this for every lens and enjoy the cheep darkfeild goodness!
Microscope: Watson Barnett Bactil
Camera: Kodak DX7440 (not SLR, no attachment for the microscope, i just hold it over the lens and pray )
Being a joiner (carpenter) I made myself an optical bench years ago to couple both the camera on a focusng slide and a rotating subject platform together. I also made a copy stand in timber. Both now disposed of years ago.
Much of the first photographic eqipment of course was made out of wood, not just the cameras but tripods too. In fact some professionals used to prefer wooden over metal tripods because they considered that timber damped out vibration better than metal that had a tendency to "ring" or vibrate in sympathy with road traffic noise etc.
DaveW
DaveW
Since You Asked...
It is not really something I made from scratch but thrown together with stuff I had lying around and in desperate need of being thrown away. However...I took an old cheap desk lamp that the switch had given out on. I removed the lamphousing and the switch, along with the lamp cord and discarded them. I then found a short broadheaded screw or bolt that had the exact same threads as those of my off camera flash cord. I attached the cords hot shoe via the threaded bolt to the desk lamps base and there I had it. A functional mount for using my flash, off camera around the house, or for use in a mini studio set up.
Here are some "homemade" links:
http://pentaxhacks.blogspot.com/
http://forums.dpreview.com/forums/read. ... e=22992716
Harold
Harold
You evidently read this DIY article first then?
http://photocritic.org/macro-photography-on-a-budget/
DaveW
DaveW
<< You evidently read this DIY article first then? >>
I saw / read this - or similar a fair while ago - but for something I made recently I really pushed the boat out and went 'up market'.
Bought a completely faulty 28-80 zoom from a local shop for a fiver
Stripped all the guts out, leaving just the mount + casing (onhe piece moulding)
Found some plastic waste pipe fittings that just fitted inside the cyl. casing
Turned a wooden 'bung' with rms threaded hole
Tried a few objectives.
Nothing against the 'lens cap' approach - but with above, you get a much larger reference area (rather than essentially an axial plane) for 'other bits'
pp
pp
Boxes, bottlebottoms, bits, bobs.
I've built so many odd-ball illumination systems I've lost count.
A 4x5 view camera, rosewood boards, aluminum rails, with a double extension scheme to take the rail up over 30 inches for macro use.
I took a Nikon extension tube, cut a hole in the side, added a 45 degree angled beam splitter mirror for epi-illumination on a bellows.
A macro stand patterned after a home made multiphot.
The double bellows adapter pictured in Lester Lefkowitz's manual.
I mounted a Nikon 5 objective RMS turret on a Nikon BP-4 bellows.
The Christmas issue of Amateur Photographer has what might be called a Blue Peter article: "A DIY Christmas".
For £4 you can make a ring flash adapter; for £3 an adapter for using a lens from a medium format bellows (tilt/shift/Lensbaby functions) on a 35mm camera; for £1 a flash diffuser; for 'nothing' some shaped masks (vignettes).
Harold
Harold
I have made my own dark field stops simply by cutting out a small piece of opaque material and sticking it to a condenser filter. Also if I slid the filter out of its position slightly I could get a kind of 3D effect.
