Has anyone used the Nikon CFI60 tube lens?
Interesting stuff.
However, I would advise caution until we have some results.
The nikon tube lens is designed for a maximum field width of around about 22-24mm. The mitutoyo is probably not designed for a microscope, but an industrial camera. Planned field width would be tiny.
I am not saying that they won't work but that we are in virgin territory here.
Ultra wide field widths are not only pushing the boundaries for objectives, but also for tube lenses.
Continuing to look at this diagram, the diameter at the narrowest part is 36mm so ignoring the thickness of metal surrounding the glass (which from the photos is non negligible, but the thickness is unknown) then the aperture would be 200/36= f/5.5.rjlittlefield wrote: BTW, we can tell from this diagram that the Nikon tube lens is weakly telephoto -- physically shorter and closer to the sensor than its 200 mm focal length would suggest.
Also, assuming that the tube lens is a fairly simple two or three element design, could it be assumed that the entrance and exit pupils are coincident near the middle of the physical lens? In that case they are 151.2 + 29/2 = around 165mm from the sensor plane.
Here are some pictures of the mounted tube lens that came with the Mitutoyo 10X:Craig Gerard wrote: Rogelio,
Could you provide more details regarding the "mounted tube lens that came with the Mitutoyo" ?
Here the tube lens with the adapter to M42 + M42 to Canon EOS adapter:
The setup (the camera is not shown, it goes with the AS shown on the picture):
The clear diameter of the tube lens is 30mm.
- Craig Gerard
- Craig Gerard
- Craig Gerard
Looks similar to these ants uploaded by Gustavo Mazzarollo:
http://www.photomacrography.net/forum/v ... ght=#74229
A high resolution version of Rogelios great looking ant shot with the Mitutoyo 5x/0.14 M Plan Apo can be downloaded here: http://farm6.static.flickr.com/5082/537 ... a043_o.jpg
Thank you to all for the comments about the ant picture (I think it is an ant).
Thank you John for posting the full res version.
The posted version of the image was with all the frame raw pre-sharpened before stacking. I have a version with all the frame without pre-sharpening before the stacking, I will try to post a comparison between them.
Actually there is an ebay auction of a Mitutoyo Plan Apo 5x starting at $275 new demo version (I bought mine for $225 used).
