www.photomacrography.net :: View topic - How does this one look?
scitch
PostPosted: Wed Sep 01, 2010 10:21 pm    Post subject: How does this one look? Reply with quote
I'm a little bit happier with this image than I have been of my past few stacks. In the full-size version, I can zoom in quite a bit before I see too much pixelation in photoshop. I still haven't received my external flash, so the lighting isn't good, but I was just testing to see how using flash would help reduce vibration problems.
This is a ZS stack of 21 images taken with a bellows at 21 cm (sensor to objective tip) with a Leitz 10X EF objective and the pop up flash diffused with two sheets of notebook paper above and below.
I was wondering as I set up . . . if camera lenses have longer working distance when mounted backwards, is the same true of microscope objectives?
PostPosted: Wed Sep 01, 2010 11:42 pm    Post subject: Re: How does this one look? Reply with quote
Nope, doesn't work that way. If you try reversing a microscope objective, typically its focus point will be someplace inside the barrel. Also the quality will be awful because of aberrations. You have to use them the way they're designed.
