Hi there. I currently use Helicon for my image stacks - it works well for the most part, and more importantly works perfectly smoothly with Lightroom. However I am so sick of the halos and ghosting in images. It's definitely time to learn Zerene.
I've found though that Zerene doesn't work with Raw files as far as I can tell? I've waded through pages but can't find a quick start guide.
Usually my process overview is as follows:
-load .cr3 files into Lightroom catalog
-export to Helicon to stack
-save stacked .dn image back to Lightroom
-edit/colour grade file
-tidy up in Topaz Labs
-save back to Lightroom
It's looking to me like I have to edit all the images for the stack in Lightroom first, export as jpg, import into Zerene, and go on from there.
Could anyone help please?
How do I export Raw images from Lightroom to Zerene then save back into Lightroom so I can edit the stacked image?
Thank you,
Kathleen
Raw images in Zerene
Re: Raw images in Zerene
Hi, I'm Rik Littlefield, the fellow who wrote Zerene Stacker.
It sounds like you'd like to be using the Lightroom plugin that is provided by Zerene Stacker as a Prosumer/Professional feature.
Documentation on how to install and use the plugin can be read at https://zerenesystems.com/cms/stacker/docs/workingwithlightroom ("Working With Lightroom"). See the first section, labeled "Lightroom Plugin". Note that when you install the plugin, you'll have to acknowledge that it's a Pro-level feature and you'd like to begin the 30-day trial of that feature.
After that, your best attack on halos is to learn how to use the DMap slider and how to use retouching to combine the best bits of PMax and DMap outputs. There's an overview of that process at https://zerenesystems.com/cms/stacker/docs/howtouseit ("How To Use Zerene Stacker"), with a lot more information in tutorials that are linked on the Tutorials index page at https://zerenesystems.com/cms/stacker/docs/tutorials/tutorialsindex .
For new users, I usually recommend to start at the top of the Tutorials index page and just read/watch items in order from the top down, going at least through "Tips for Retouching" and "Keyboard and Mouse Shortcuts". The two video tutorials on retouching are particularly important, because there are some features that you're not likely to find by experimenting. I also recommend to read the FAQs, since those are likely to answer some questions you might not have thought to ask.
I hope this helps. If you have further questions, feel free to either post here or send email to support@zerenesystems.com . I'm also the fellow who answers all the email there.
Generally it is best to use the least-compressed, highest-bit-depth file format you possibly can in Zerene. So I would not use your workflow. I'd recommend converting he RAW files to tiffs, editing them in lightroom (without excessive sharpening), then stacking the tiffs in Zerene, and working with the output tiffs from Zerene.
Here is my workflow.Lou Jost wrote: ↑Sun Mar 26, 2023 6:04 pmGenerally it is best to use the least-compressed, highest-bit-depth file format you possibly can in Zerene. So I would not use your workflow. I'd recommend converting he RAW files to tiffs, editing them in lightroom (without excessive sharpening), then stacking the tiffs in Zerene, and working with the output tiffs from Zerene.
- Shoot in JPEG not RAW.
Import images into Zerene as JPEG and perform both PMax and DMAP stacks
Edit the stacked output image using both PMAX and DMAP as well as individual images and then save with a compression quality of 11 as a JPEG
I import into GIMP for editing the stacked image for color, contrast correction and cropping and export that at 98% as my final image as a JPEG
In Adobe Photoshop there is batch processing. You can learn about it online. You can apply any complicated RAW development to all the pictures in a folder automatically.
- iconoclastica
Do we have topics here where the comparison between stacking direct jpg and raw-->Tiff was made?Lou Jost wrote: ↑Sun Mar 26, 2023 6:04 pmGenerally it is best to use the least-compressed, highest-bit-depth file format you possibly can in Zerene. So I would not use your workflow. I'd recommend converting he RAW files to tiffs, editing them in lightroom (without excessive sharpening), then stacking the tiffs in Zerene, and working with the output tiffs from Zerene.
--- felix filicis ---
I don't know if there is a specific comparison but I have often done stacks both ways. I usually do stacks with jpgs but I convert to tiffs first for important stuff, or stuff that seems under- or over-exposed. I like to reduce sharpening a bit, and also reduce highlights, and sometimes raise shadows.
