Now the flashes are like 4-5cm back and there's a good space from the flash light to the diffuser surface.
I did some previous "projects"...
https://www.photomacrography.net/forum/ ... highlight=
But now I couldn't resist a very good promotion at Olympus Portugal (almost 50% off and got the STF-8 twin flash... this flash will also allow for bracketing with flash ( I tried.. the camera waits for the flash to recharge when bracketing a sequence of photos)
The frame... (almost) all the parts are "SmallRig" ...
The diffuser is a "sandwich".. 2x a frame I designed and printed.. 2x 52mm Cokin series P rings.. and a piece of Savage Tanslum diffuser sheet.
I could have used only one diffuser frame and only one Cokin ring .. but using two rings I don't lose the thread in the lens mouth and I can (if I want) add a Diopter, or filter in the lens mouth (red in the drawing)
I modified the design of the diffuser .. it is 30 cm in diameter (12 inches) .. sometimes it was difficult to get right with the object / insect position because I didn’t see anything in front of me .... with the butterfly shape and the openings, like this I already see the lens mouth and the plants in front of me.
added 2 extension rings.. this still pulls the flashes further back ..
I haven't had time to test this out a lot because it's still very cold and there are almost no insects yet.
a large number of Oxycarenus sp...
if you want to try it yourself i'm more than happy to share the *.STL file ready for printing
THE FILE IS HERE
https://drive.google.com/file/d/1l0dGYO ... sp=sharing
