Just in case someone needs a heat-resistant material or if someone needs a good black-body radiator:
https://www.youtube.com/watch?v=aqR4_UoBIzY
Heat resistant super black body compound
Interesting!!
Reminds me of the silica foam that's was used on the Space Shuttle tiles. There was an old video of a 2" cube that was heated red hot and picked up by the corners with bare fingers (no gloves). The thermal resistance of the foam was so high that it couldn't deliver enough heat to the fingers from the cube corners to burn.
~Mike
~Mike
had to see that - insane!mawyatt wrote:Interesting!!
https://interestingengineering.com/vide ... bare-hands
I expect the key factors are very low thermal mass of the outer layer, combined with high resistance (good insulation) to lower layers. Those two factors would mean not much heat available to burn the fingers.Lou Jost wrote:I wonder if thermal resistance may be more important than black-body radiation to explain the videographer's ability to touch the material right after it is red-hot. He said it was due to the efficient radiation of heat....
Then efficient radiation makes the stuff cool down even faster. But I think that's not so important. An isolated sheet of aluminum foil can be heated red hot and touched without pain only 3 seconds after removing the torch. (Yeah, I just now checked.)
