Brian V.
Following a discussion here http://www.dpreview.com/forums/post/56372729 started by user SteB on odd DOF effects using an add-on diopter. I did some DOF tests with my sigma105 lens at infinity focus with a +25 diopter (MSN202) compared to an MPE-65 lens at the same magnification (around 2.3:1). The target is an angled ruler.
You can see from the image below the sigma 105 +diopter shots have a much shallower DOF than the MPE-65. It appears the use of a diopter to increase magnification does not increase the apparent aperture of the system resulting in the shallower DOF. The DOFs actually approximately matched with the sigma at F22 and the MPE-65 at F7.1
I assume the same effect is seen using reversed lenses on the front of another lens.
Brian V
