But I was totally not prepared for what I saw when I looked close.
This is crossed-eye stereo:
This is apparently something like a samurai wasp, though the group is so large that any specific ID is not likely to be correct. The samurai wasp, under consideration for biocontrol of brown marmorated stink bug, is Trissolcus japonicus, Hymenoptera:Scelionidae. https://en.wikipedia.org/wiki/Scelionidae describes the family as
Um, yeah, "highly sculptured" seems like an excellent description!a very large cosmopolitan group (over 3000 described species in some 176 genera) of exclusively parasitoid wasps, mostly small (0.5–10 mm), often black, often highly sculptured, with (typically) elbowed antennae that have a 9- or 10-segmented flagellum.
Here is an overview:
As shown here, the abdomen has a distinctive and unusual forked shape. But other specimens from the same brood do not have the same shape, and I'm pretty sure the one shown here is just a quirk of shrinkage as it dried out.
Finally, here is a close crop showing the hamuli, just because I was curious. These are small, but not quite as small or fragile as the ones from my whitefly wasps, HERE.
All images are from the same stack, 267 frames at 0.003 mm step size, shot with Mitutoyo M Plan Apo 20X NA 0.42 on Componon 135 mm f/5.6 as a tube lens. Nominal magnification would be 13.5X, measured is 13.6X. Two flashes through two separated layers of matte mylar diffusion film. Synthetic stereo at +-5 degrees.
