So
Tapinoma it is... I am glad that my ant facial recognition hasn't let us down!
Common knowledge is that the insect body consists of three major divisions, with different major functions. These divisions are referred to as follows: the front division as head (or caput), the middle division (mesosoma) as thorax and the hindmost division (metasoma) as abdomen.
Now in the higher hymenoptera which the ants belong to, the original ovipositor has evolved into a sting. To make more effective use of this sting, it was advantageous to have the hind part of the body (metasoma) more freely movable than a broad attachment between the original thorax and abdomen, as seen in the more "primitive" hymenoptera (like the sawflies) allows for.
Hence, in the higher hymenoptera a constriction (" wasp waist") has evolved that allows for better motility of the last division of the body (metasoma).
But morphologically this constriction has evolved within the original insect abdomen: In the higher hymenoptera the original 1st abdominal segment, now referred to as propodeum (sometimes also called epinotum) is fused anteriorily to the original thorax. And hence it makes some sense to call this middle division of the body now just mesosoma or sometimes alitrunk, but not thorax anymore. And then to be consequent, to call the hindmost body division not abdomen anymore but just metasoma or gaster.
In ants the distinctive linkage of the mesosoma (here alitrunk) and metasoma (here gaster) consists of one or sometimes two segments, derived from the 2nd and 3rd segment of the original abdomen.
The first segment of the linkage is called the petiolus (original 2nd abdominal segment) and the second (if present, like in the Myrmicinae) is called the postpetiolus (original 3rd abdominal segment).
Here in your dolichoderine
Tapinoma the "linkage" consists only of a small petiolus which is strip-shaped and depressed. This allows for raising the gaster in the air toward the dorsal side. This makes sense as in the Dolichoderinae the sting is reduced, is hence vestigal or absent. Instead the Dolichoderinae have evolved secretions, that are toxic or repellent for other ants/insects, which are released from glands of the gaster. It's probably what you can smell as blue cheese odour in your
T. sessile.
Ants of other subfamilies with a sting present, often have a rather large petiolus (and sometimes postpetiolus) with dorsal hump and muscles, enabling them to bend the gaster to the ventral side, to thrust the sting between their legs and place them into the target that way.
Now, these are great images/stereos, Rik!
Such quality images really deliver evidence for first morphological studies and discussion without the imperative use of an SEM.
Like you, I am particularly intrigued by what looks like a peg protruding from the alitrunk against the anterior side of the petiole. And it looks to me that on the opposite side, the anterior side of the petiolus, there seems to be a patch of hairs. I wouldn't expect it to be a solid, thin conncection. I would rather expect the protrusion of the alitrunk to be touching the hairs from the opposite side of the petiolus.
(But then cross-eyeing at the last stereo pair again, I see your point that it looks like some more solid connection.)
Because these structures must have some kind of function, this would make sense as follows:
My speculation would be: Protruding structure touches and bends and thus stimulates mechanosensory hairs according to the relative position of the petiolus towards the alitrunk.
(Or if the connections was really solid, then I would expect it to be bedded flexibly in this socket structure, like the protrusion on the alitrunk would be suspended by membranes in this socket, and the movement could then be registered by sensory cells in the socket too, and not, or not just, by sensory hairs on the opposite side ...)
In both ways the organism gets sensory feedback about the position/movement of the petiolus and gaster relative to the alitrunk and can sense gravity.
Such sensory feedback in organisms is generally called proprioception.
Bottom line, the answer to your question:
What is this bit of anatomy?
would be:
A mechanosensory receptor.
--Betty
Atticus Finch: "You never really understand a person until you consider things from his point of view
- until you climb into his skin and walk around in it."
Lee, N. H. 1960. To Kill a Mockingbird. J. B. Lippincott, New York.
