Of course I got curious about the technique, so I harvested a few of the knots just before they would have fallen off naturally.
Shown here is one knot that caused me to scratch other parts of my head, wondering how it came to be.
Transparent version, immersed in fluid:
(stereo pairs are crossed-eye)
Opaque version, photographed dry:
In the opaque version, it's easy to see that at the bottom of the knot there are three degraded monofilament strands. Those are places where the strands descended into skin and were absorbed, while the knot stayed above the surface, protected by an oily ointment.
Meanwhile, in the transparent version you can see that two of the three strands run essentially straight through the knot, with the third strand locked around them in a series of hitches.
At the other end of the knot, outside the frame of these photographs, each strand of monofilament terminates in a cleanly cut end.
I encourage you to stop at this point and carefully think about the situation: the stitch is made with a single strand of suture, but the knot incorporates three strands, each strand buried in skin below the knot and cut off cleanly above the knot, giving a total of 6 ends.
How and why was the knot made this way??
If you have been trained in suturing, the answer is probably obvious, although six ends may still give pause to think.
But if you have not been trained in suturing, then you may ponder long and hard and never come up with a plausible explanation. At least I hope that's the case, because that's certainly what I did.
While you consider the question, let me show you how the knot appeared a day or two before it came off.
Yep, three strands at the outer end of the knot, cleanly clipped. Presumably the other three strands dive back into the skin at the other end of the knot, but no details of that can be seen.
In the old days, I do not know how I would have solved this mystery, short of asking the surgeon.
But these days we have the internet, and once I found the right search string (youtube how to tie off a running suture), numerous videos appeared from which the answer could be gleaned.
Spend 20 seconds at the following URL, and you'll see the process as it is explained at 12:30-12:49 of the Duke Suture Skills Course: https://www.youtube.com/watch?v=TFwFMav_cpE&t=750s
In case that went by too fast, here's the schematic version showing various stages.
There's another bit of a different knot that I'm still unclear about, but I'll leave that for another day.
I hope you find this at least slightly as interesting as I did.
Technical: high mag photos with Mitutoyo M Plan Apo 5X with Raynox DCR-150 on short extension giving 4.04X (5.5 mm field width on Canon R7, 22.8 mm sensor), continuous illumination with Jansjö LED. The fluid for immersion was Ronsonol lighter fluid, which was the first gentle solvent that would remove the oily ointment. Ethanol and acetone wouldn't touch the stuff. The in-situ macro shot was done with a 100 mm macro lens on the Canon R7, on tripod and tethered to my computer so I could see what I was doing to fly my head for framing and focus. That one is flash illumination, a 2-frame stack with extensive retouching to compensate for slight shift in view point.
